1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  <2013>  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  <2013>  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Subject: RE: Record Parameters in Asyn Port Driver
To: "Igor H. Soares Nunes" <[email protected]>, "[email protected]" <[email protected]>
Date: Mon, 5 Aug 2013 17:28:58 +0000
Hi Igor,
The idea of asyn port drivers is that they don't know anything about the EPICS records.  They only know about the standard asyn interfaces (asynInt32, asynUInt32Digital, asynOctet, etc.).  The device-independent device support in asyn/devEpics is the only code that knows about the record fields.
Can you please explain what you want your driver to do, and I can probably tell you how to do it without your asyn port driver needing to know anything about the record fields.
From: [email protected] [[email protected]] on behalf of Igor H. Soares Nunes [[email protected]]
Sent: Sunday, August 04, 2013 2:27 PM
To: [email protected]
Subject: Record Parameters in Asyn Port Driver
Hello everyone,
I'm developing an IOC using Asyn Port Driver, and I couldn't find out how to get some record parameters in the device support code (cpp file).
I need to get the INP and OUT parameters (port,addres,mask,timeout,...) and also NOBT for mbbi and mbbo records. As well as parameters for ai and ao records (EGUF, EGUL, etc).
Can anyone help me?
Centro Nacional de Pesquisa em Energia e Materiais (Cnpem)
Laboratório Nacional de Luz Síncrotron (Lnls)
Grupo de Diagnóstico de Feixes (Dig)
RE: Record Parameters in Asyn Port Driver Igor H. Soares Nunes
Prev: RE: Modbus Mark Rivers
Next: Re: Modbus Zenon Szalata
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  <2013>  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Prev: Record Parameters in Asyn Port Driver Igor H. Soares Nunes
Next: RE: Record Parameters in Asyn Port Driver Igor H. Soares Nunes
