1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  <2013>  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  <2013>  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Subject: database breakpoint, dbb(), and large linksets
To: EPICS Tech-Talk <[email protected]>
Date: Thu, 08 Aug 2013 10:32:06 -0400
Greetings,
I am wondering if anyone has experience setting database breakpoints on large locksets?
I had not used dbb() until recently when someone here tried to use it on a particular record and it failed. In particular the IOC stopped communicating via Channel Access, though the console continued to respond to for example dbl. If I then try the command dbstat the console stops responding.
Further testing revealed that dbb worked for some records in the IOC but not for others. In particular large linksets seemed to be a problem. I tried a second IOC (different device types) and this was true there also. I can't give a specific linkset size, it seems to work fine for a few tens of records in a link set. I took a large linkset and trimmed it until it worked. Adding back one record could reproducibly cause it to then fail.
Any advice appreciated.
John Dobbins
Cornell Laboratory for Accelerator-based Sciences and Education
Prev: Multiple Instances of JCA on Same Computer? Olson, Thomas C.
Next: Re: motor record: continuously update limit switches Konrad, Martin
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  <2013>  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Next: motorRecord simulation & STUP field Konrad, Martin
