1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  <2013>  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  <2013>  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Subject: Re: motorRecord simulation & STUP field
To: "Konrad, Martin" <[email protected]>
Date: Fri, 9 Aug 2013 11:34:47 -0500
Hello Martin,
What is value of the motor record's MSTA field for the simulated
motors when the motor record is idle; no move requests?
Your EPICS_HOST_ARCH is set to linux-x86_64-debug when you
build the motor module; is that true?
Ron
On 8/9/2013 9:05 AM, Konrad, Martin wrote:
Which release of the motor module are you using?
R6-8, but the behavior I see is the same with R6-7-1.
Martin
motorRecord simulation & STUP field Konrad, Martin
Re: motorRecord simulation & STUP field Konrad, Martin
Prev: Re: motorRecord simulation & STUP field Konrad, Martin
Next: Re: motorRecord simulation & STUP field Pearson, Matthew R.
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  <2013>  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Next: [asyn] link already open! Pavel Maslov
