1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  <2013>  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  <2013>  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Subject: Re: vxWorks (tNetTask): arpresolve: lookup failed (resource shortage or network configuration error -- check netmask)
To: [email protected]
Date: Mon, 12 Aug 2013 08:59:21 +0200
On 30.07.2013 23:45, Brad Cumbia wrote:
Has anyone every experienced these errors before.
Sometimes the ioc boots and sometimes it doesn't
That can happen depending on the number of systems on your network. Try to increase the number of ARP table entries in the vxWorks kernel. The default is only 20. I have set
#define ARP_MAX_ENTRIES 500
That should help.
Dirk
<Feb/06 09:57 am>0xffb77e0 (tNetTask): arpresolve: lookup failed
(resource shortage or <Feb/06 09:57 am> network configuration error --
check netmask) <Feb/06 09:57 am>0xffb77e0 (tNetTask): arpresolve: lookup
failed (resource shortage or <Feb/06 09:57 am> network configuration
error -- check netmask) <Feb/06 09:57 am>0xffb77e0 (tNetTask):
arpresolve: lookup failed (resource shortage or <Feb/06 09:57 am>
network configuration error -- check netmask) <Feb/06 09:57 am>0xffb77e0
(tNetTask): arpresolve: lookup failed (resource shortage or <Feb/06
09:57 am> network configuration error -- check netmask) <Feb/06 09:57
am>0xffb77e0 (tNetTask): arpresolve: lookup failed (resource shortage or
<Feb/06 09:57 am> network configuration error -- check netmask) <Feb/06
09:57 am>0xffb77e0 (tNetTask): arpresolve: lookup failed (resource
shortage or <Feb/06 09:57 am> network configuration error -- check
<Feb/06 09:57 am> neAttached TCP/IP interface to dc unit 0 <Feb/06 09:57
am>Attaching network interface lo0... done.
vxWorks (tNetTask): arpresolve: lookup failed (resource shortage or network configuration error -- check netmask) Brad Cumbia
Prev: Re: EtherCAT [SEC=UNOFFICIAL] Dirk Zimoch
Next: Re: [asyn] link already open! Dirk Zimoch
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  <2013>  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Prev: RE: vxWorks (tNetTask): arpresolve: lookup failed (resource shortage or network configuration error -- check netmask) Hill, Jeff
Next: Power over ethernet Emmanuel Mayssat
