Hi:
The parameter to PVUtil.getDouble(pv) must be one of the PVs that's an input to the script.
CSS BOY calls your script after handling the PV connections, asserting that the PVs have values, and then you can use this:
# pvs[] are the input PVs to the script.
# Assume pvs[0] is the 'voltage' PV:
voltage = PVUtil.getDouble(pvs[0])
Read the online help, look at one of the BOY Examples that are included with CSS.
Kay
On Aug 17, 2013, at 5:25 PM, sahil jee <[email protected]<mailto:[email protected]>> wrote:
Dear community
I am trying to acess PVs of my ioc. My ioc(stream device) is running properly and containing "readvoltage" and "readcurrent", "calculatedpower" as PVs.
In my CSS application, I want to access the above two mentioned PVs in order to make some calculations.
I am trying python embedded script as follows;
voltage = PVUtil.getDouble(readvoltage) # readvoltage and readcurrent are PVs in my ioc
current=PVUtil.getDouble(readcurrent)
power = valtage*current
calculatedpower.setValue(power) # calculatedpower is a PV in my ioc
When I run my opi it gives me the error;
"readvoltage" not defined?
In my opi, I have two text input widget which are receiving readvoltage PV value and readcurrent PV value, and one Text Update widget which will receive the calculatedpower PV value.
Looking for your kind reply.
Thank you all.
- Re: CSS: Can not access PVs in python script Sahil
- CSS: Can not access PVs in python script sahil jee
Fwd: Can not access PVs in python script sahil jee
<2013>
2025
<2013>
2025
