1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  <20132014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  <20132014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025
Subject: Re: Channel Acess
To: Ganesh Jangir <[email protected]>
Cc: [email protected]
Date: Tue, 20 Aug 2013 09:55:19 -0500
Hi Ganesh,
On 08/20/2013 07:51 AM, Ganesh Jangir wrote:
In which layer(s) of OSI Model the Channel Access(CA) fits?
The TCP and UDP protocols are commonly mapped to layer 4 (Transport), and Channel Access makes use of both of those protocols. Channel Access itself implements aspects of both layers 5 (Session) and 6 (Presentation).
> I believe it is network layer. Is this correct??
Layer 3 (Network) is better regarded as the IP Internet Protocol layer provided by the operating system which sits under the TCP and UDP protocols. See http://en.wikipedia.org/wiki/OSI_model#Examples for a useful table.
> In which layer(s) of OSI Model the EPICS fits?
EPICS is a tool-kit; it provides various parts that can be mapped to layers 5 through 7 depending on how and where you use them.
- Andrew
Advertising may be described as the science of arresting the human
intelligence long enough to get money from it. -- Stephen Leacock
Channel Acess Ganesh Jangir
Prev: Using MEDM for timing nalaka samarasinghe
Next: RE: Using MEDM for timing Mark Rivers
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  <20132014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025
Prev: Re: Channel Acess Kevin Peterson
Next: Using MEDM for timing nalaka samarasinghe
ANJ, 20 Apr 2015 Valid HTML 4.01! · Home · News · About · Base · Modules · Extensions · Distributions ·
