1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  <2013>  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  <2013>  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Subject: Re: Using MEDM for timing
To: <[email protected]>
Date: Tue, 20 Aug 2013 11:18:45 -0500
And, you need to put these records into an EPICS IOC. MEDM will be used to visualize and control the process variables (PVs) of that IOC (for example, see the figure Mark provided). The PVs, provided by the various records in the IOC, will provide controls and responses for the components you need for your intended application.
Pete
On 8/20/2013 10:17 AM, Mark Rivers wrote:
I think you are asking the wrong question.  You don’t need a special
medm widget for that, the standard widgets can be used.
You do probably need 2 things:
1) A feedback record.  The EPICS epid record can be used for this.  It
can read the temperature from your readout device and control the power
to a power supply using a D/A converter, for example.
2) Some other record or client to control the setpoint of the feedback
record.  You could use the sscan record in table mode to generate an
arbitrary temperature profile, for example. Or you could use a client
like Python, IDL, etc.
I have attached a screen shot of one of our temperature control
screens.  At the time I took this screen shot the thermocouple was
broken, so the temperature reading is meaningless, but you get the idea.
[mailto:[email protected]] *On Behalf Of *nalaka samarasinghe
*Sent:* Tuesday, August 20, 2013 9:50 AM
*To:* [email protected]
*Subject:* Using MEDM for timing
Hi All,
I need to use MEDM application for building a programmable temperature
controller. That is the system should be able to heat some fluid at some
pre determined temperature for a period and increase the temperature to
a higher value and keep it for some period.
I could not find any widget that i can use for this application. It is
appreciated if you could give me some guidance on the above.
Thanks & Regards,
Nalaka
Pete R. Jemian, Ph.D.                <[email protected]>
Beam line Controls and Data Acquisition, Group Leader
Advanced Photon Source,   Argonne National Laboratory
Argonne, IL  60439                   630 - 252 - 3189
   Education is the one thing for which people
      are willing to pay yet not receive.
Using MEDM for timing nalaka samarasinghe
RE: Using MEDM for timing Mark Rivers
Prev: Re: Channel Acess Kevin Peterson
Next: Comms issue with New Focus 8752 motor driver tim.hayton
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  <2013>  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Prev: RE: Using MEDM for timing Mark Rivers
