1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  <2013>  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  <2013>  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Subject: CAJ can't handle DBR_String
To: tech-talk <[email protected]>
Date: Wed, 21 Aug 2013 11:44:29 +0200
Hi all,
it seems CAJ can't handle DBR_String.
If you request the value of a stringout or stringin EPICS variable you
always get a NullPointerException.
Also if you ask for the DESC field of any PV you'll get same error.
If you dig deeper you see the DBRType of the created channel is
UNKNOWN.  Where comes this type come from? You find the problem in
"com.cosylab.epics.caj.CAJChannel.connectionCompleted(int sid, short
typeCode, int elementCount) ". This function gets the parameter
"typeCode" and the value of this parameter is "UNKNOWN" instead of
"STRING". But who sets the "typeCode"? The "typeCode" will be extracted
from the CA response header (AbstractCAResponseHandler) and here ends my
trace.
Did I miss something? Please check my source code and tell me what to do
to get strings.
public class CAJBugTest {
    public static void main(String[] args) throws Exception {
        JCALibrary jca = JCALibrary.getInstance();
        Context ctxt = jca.createContext(JCALibrary.CHANNEL_ACCESS_JAVA);
        Channel ch = ctxt.createChannel("INFOCL:scale.DESC");
        ch.addMonitor(DBRType.DOUBLE, 1, Monitor.VALUE, new
MonitorListener() {
            @Override
            public void monitorChanged(MonitorEvent ev) {
                System.out.println(ev.getDBR().getValue());
        ctxt.flushIO();
        Thread.sleep(5000);
        ch.destroy();
        ctxt.destroy();
Cheers,
Carsten
Aufsichtsrat: Vorsitzender Prof. Dr. Dr. h.c. mult. Joachim Treusch, stv. Vorsitzende Dr. Beatrix Vierkorn-Rudolph
Geschäftsführung: Prof. Dr. Anke Rita Kaysser-Pyzalla, Thomas Frederking
Postadresse:
Hahn-Meitner-Platz 1
D-14109 Berlin
Re: CAJ can't handle DBR_String Kasemir, Kay
Prev: EPICS Qt Framework Ricardo Fernandes
Next: CSS DataBrowser/Trend : legend font Takashi OBINA
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  <2013>  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Next: Re: CAJ can't handle DBR_String Kasemir, Kay
