1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  <20132014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  <20132014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024
Subject: Re: StreamDevice communication problems
To: [email protected]
Date: Mon, 26 Aug 2013 20:28:32 +0200
one nice feature for that could be using the streamdevice debug output
. It takes a while sorting it out because it will print out everything
but it helps often.
Try logging it to a file or if you use procserv just take the logfile.
Nice starting point is "grep uffer logfile.txt"
that shows the "input Buffer" as well as the "output buffer"
 on the epics console just enter
"streamDebug=1" to enable it.
how the output ends up in the input is rather strange.
StreamDevice communication problems Tito Körner
Prev: RE: StreamDevice communication problems Mark Rivers
Next: Re: ICALEPCS Agenda - Andrew Johnson
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  <20132014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024
Next: Re: StreamDevice communication problems Dirk Zimoch
ANJ, 20 Apr 2015 Valid HTML 4.01! · Home · News · About · Base · Modules · Extensions · Distributions · Download ·
