1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  <2013>  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  <2013>  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Subject: RE: EhterCAT terminals [SEC=UNOFFICIAL]
Date: Thu, 29 Aug 2013 04:07:50 +0000
Actually, upon further reading I don't think the EL1262 can do what we want so forget about that.
Damien
> -----Original Message-----
> From: [email protected] [mailto:tech-talk-
> [email protected]] On Behalf Of LYNCH, Damien
> Sent: Thursday, 29 August 2013 9:25 AM
> To: [email protected]
> Subject: EhterCAT terminals [SEC=UNOFFICIAL]
> Hi,
> Am I right in assuming that we would not have to write any code to use
> EtherCAT terminals that are not already in use at other labs? It looks like the
> important thing is to get the ESI files from the vendor. I notice there are two
> Python scripts (expandChain.py and maketemplate.py) that are needed to
> produce the scanner XML configuration file and the database template files
> for each terminal type. I could not see them in the DLS EtherCAT package.
> Where do they come from?
> On another note, we need a 1 MHz counter and are thinking the EL1262 XFC
> terminal could do the job. The scanTest example IOC uses a XFC terminal but
> I wanted to double check that there should be no problem using an XFC
> terminal.
> Thanks,
> Damien
RE: EhterCAT terminals [SEC=UNOFFICIAL] nick.rees
EhterCAT terminals [SEC=UNOFFICIAL] LYNCH, Damien
Prev: RE: TPG261 : "message too small=0" for EPICS Mark Rivers
Next: RE: EhterCAT terminals [SEC=UNOFFICIAL] nick.rees
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  <2013>  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Prev: EhterCAT terminals [SEC=UNOFFICIAL] LYNCH, Damien
