1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  <2013>  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  <2013>  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Subject: Re: epicsThread
To: Michael Davidsaver <[email protected]>
Date: Thu, 29 Aug 2013 05:54:11 -0700 (PDT)
   Still i don't understand how i can implement this concept in my application.   As i am using Asyn Driver, i have used 2 different reason  in asynInt32  and for 2 record.
asyn reason (1) delay    -> i put one loop which  read system time and compare with there time specified by value field of the PV by ->    caput  <PV name>   <value time>        if the system time is greater than <value time>   loop break and record processing complete with return value asynSuccess.
asyn reason (2)  currenttime   -> read current time of the system   -> it is simple scanning  record with SCAN field of 1 second.
If in project i define only one PV with any one case of above, it works fine....
But if i use 2 PV and using both function same time, when i put delay value with $ caput <PV name> <value time>   and monitor second  PV on other terminal with camonitor    <PV name (PV reading current valu)>   the second PV read out hanged till completion of first PV complete it's delay time.
Means reason (1) delay is keep execution in loop and prevent execution of other PVs   record processing.
So i think i have to run loop in separate thread and kill that thread after completion of delay time and return asynSuccess.    I am using asynDriver and it is necessory to return with asynSuccess.
Or is there any other way to do this?
from https://pubweb.bnl.gov/~mdavidsaver/epics-doc/epics-devsup.html#_asynchronous_example  example i am not able to get how to do multi threading.
With regards
Vikram
To: Vikram Bhagat <[email protected]>
Sent: Monday, August 26, 2013 4:22 PM
One mechanism for accomplishing what you ask is a delayed callback based on a timer.  When coupled with asynchronous records (what the asyn module is based on) this gives a way to have long delays in record processing without locking everything up.
For an example see
Michael
On 08/26/2013 04:18 AM, Vikram Bhagat wrote:
Dear all,
      I want to know how to create and handle EPICS thread at run time.
In my application, i am using serial communication.   I am reading/writing data from serial port.
I am using Asyn driver.
In my application i have added one more functionality (asyn reason) to wait for user-define  time and then complete record processing.
In this function caput <PV name> with time in seconds will wait for that much seconds (I put one loop to read system time and check that user-defined time has been reached or not) and then "return asynSuccess".
This is working fine but problem now is->  the system is not processing any other record/PV  till the delay time will complete.  Means if i user requested delay time for 5 minutes--> the system will not process other reading or writing PV till 5 minutes complete.
How i can handle this situation? while system is waiting for time delay other record needs to be processed and have to give values or write to the output.
I think i have to create epicsThread for this delay. so it will run in separate thread and other functions can work independently. But in my case after completion of my delay i have to delete Thread ... How i can delete that Thread and make sure that my asyn driver will return asynSuccess for that delay function?
Thanks & regards
Vikram
RE: epicsThread Mark Rivers
epicsThread Vikram Bhagat
Re: epicsThread Michael Davidsaver
Prev: RE: Hardware simulator Steiner, Mathias
Next: Re: Hardware simulator Pavel Maslov
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  <2013>  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Prev: Re: epicsThread Dirk Zimoch
Next: RE: epicsThread Mark Rivers
