Yasemin,
That typically means that the device is not responding to your command, at least
not within the default timeout of 1000 ms. Are you using the same serial cable
as you did with cutecom and the same comm port parameters?
If you have a serial analyzer that you can put between the device and the cable
that would at least tell you if the device is getting the command.
Marty
On 09/05/13 08:18, Yasemin Barutçu wrote:
Hello,
I've been trying to connect to power supply by RS232. When I try the connection
with cutecom everythings work fine. But after creating an epics application and
send the "*IDN?" command I get following warning and can't read anything.
2013/09/05 16:15:56.265500 serial IDN: No reply from device within 1000 ms
Yasemin Barutçu
- RE: No reply from device within 1000 ms Mark Rivers
- No reply from device within 1000 ms Yasemin Barutçu
RE: No reply from device within 1000 ms Mooney, Tim M.
<2013>
2025
<2013>
2025
