1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  <2013>  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  <2013>  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Subject: seq and synchronous writes
To: "[email protected]" <[email protected]>, "[email protected]" <[email protected]>
Date: Thu, 5 Sep 2013 19:54:51 +0000
Hello,
I am using a state machine to control a motor setup. In each step it
basically sends a command to the motor record and waits for it to
complete. This can be detected by the "done moving" field (DMOV).
Here is how I implemented this:
state1 {
   entry {
     sprintf(stateMsg, "state 1");
     pvPut(stateMsg);
   when(foo) {
     motor = bar;
     pvPut(motor, SYNC);
   } state state2
state2 {
   entry {
     sprintf(stateMsg, "state 2");
     pvPut(stateMsg);
Unfortunately this leads to a long delay between the motor starting to
move and the update of the status message (sometimes 10 seconds!).
I suspect I'm using sequencer the wrong way here. Are synchronous pvPuts
necessary to make sure the command has been send to the motor record?
Should I move the pvPut line to the end of the entry block of state2?
Are there some best practices how to keep the state machine code clean
and readable?
Martin
Re: seq and synchronous writes Pete Jemian
RE: seq and synchronous writes Mark Rivers
RE: seq and synchronous writes Mooney, Tim M.
Prev: PMAC VME card base address issue Chen Xue
Next: Re: seq and synchronous writes Pete Jemian
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  <2013>  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Prev: RE: PMAC VME card base address issue Emma Shepherd
