1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  <2013>  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  <2013>  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Subject: RE: motor record: soft motor & DMOV
To: "'Konrad, Martin'" <[email protected]>, "[email protected]" <[email protected]>, "[email protected]" <[email protected]>, "[email protected]" <[email protected]>, "[email protected]" <[email protected]>, "[email protected]" <[email protected]>
Date: Tue, 10 Sep 2013 16:49:43 +0000
What about changing your calcout record so that is still CP on DMOV, but it writes 1 to the output whenever DMOV is 1.  Then you are not limiting yourself to transitions (which you might have missed), but you are saying "whenever DMOV changes and is 1 set the output gate".
-----Original Message-----
From: [email protected] [mailto:[email protected]] On Behalf Of Konrad, Martin
Sent: Tuesday, September 10, 2013 11:45 AM
To: [email protected]; [email protected]; [email protected]; [email protected]; [email protected]
Subject: Re: motor record: soft motor & DMOV
Hello motor record maintainers,
further investigation revealed that this problem can also occur without
motor record (cf. the new thread on
http://www.aps.anl.gov/epics/tech-talk/2013/msg01898.php). BUT: The
problem with short 1-0-1 transitions could be avoided if the record
using this data is in the same lock set as the motor record. Sure I can
use NPP+FLNK to connect other records to the motor record's DMOV field.
But unfortunately it seems motor record does not trigger its forward
link after setting DMOV to 0. This makes NPP+FLNK pretty useless for
this field...
Is it possible to trigger the forward link when DMOV goes to 0 without
breaking hundreds of other applications?
 From the documentation I was expecting that DLY=1 should stretch the
time of the 1-0-1 transition to 1 second. But that doesn't have any
effect if the motor does not need to be moved. Is this the intended
behavior (the documentation does not cover this special case)?
Any suggestions how to fix my problem?
Martin
Re: motor record: soft motor & DMOV Konrad, Martin
Prev: Re: StreamDevice communication problems Tito Körner
Next: Multiple patterns/ .sub files for the same .db file Tito Körner
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  <2013>  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Prev: Re: motor record: soft motor & DMOV Konrad, Martin
Next: Re: motor record: soft motor & DMOV Konrad, Martin
