1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  <2013>  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  <2013>  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Subject: RE: ASYN on BeagleBone ARM
To: Amien Crombie <[email protected]>, "[email protected]" <[email protected]>
Date: Mon, 16 Sep 2013 10:51:15 +0000
Hi Amien,
Is there a reason you are using Base 3.15?  Is it required for the BeagleBone?  3.15 is not yet intended for production use, and lots of EPICS modules (including asyn) have not been converted to be compatible with 3.15 yet.  I suggest you use Base 3.14.12.3.
That said, I will fix asyn so it will build with 3.15 as soon a I get a chance.
From: [email protected] [[email protected]] on behalf of Amien Crombie [[email protected]]
Sent: Monday, September 16, 2013 1:53 AM
To: [email protected]
Subject: ASYN on BeagleBone ARM
Hi
We managed to build a cross-compiled IOC on our BeagleBone that’s running Ubuntu 11.10.
Now we want to compile the BeagleBone as EPICS host.
I got 3.15.0.1 Base installed and everything works (even Base-3.14.12.3 works).
But I cannot get ASYN-4-18 (under syn_Apps_5_6\support) to compile. (Even tried latest ASYN-4-21)
Before I go and make configuration changes etc, I would like to know if ASYN will in fact compile on ARM machines ?
Thanks
Here’s my BeagleBone’s specs:
root@omap:/epics/synApps_5_6/support# cat /proc/cpuinfo
Processor       : ARMv7 Processor rev 2 (v7l)
BogoMIPS        : 274.37
Features        : swp half thumb fastmult vfp edsp thumbee neon vfpv3 tls
CPU implementer : 0x41
CPU architecture: 7
CPU variant     : 0x3
CPU part        : 0xc08
CPU revision    : 2
Hardware        : am335xevm
Revision        : 0000
Serial          : 0000000000000000
root@omap:/epics/synApps_5_6/support# cat /proc/version
Linux version 3.2.0 (william@william-VirtualBox) (gcc version 4.5.3 20110311 (prerelease) (GCC) ) #25 Wed Aug 29 14:14:06 SAST 2012
Amien Crombie
TLABS – Cape Town
GIF image
ASYN on BeagleBone ARM Amien Crombie
Prev: RDB Archiver setup Vítek Michal
Next: Re: RDB Archiver setup Jack
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  <2013>  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Prev: ASYN on BeagleBone ARM Amien Crombie
Next: RE: ASYN on BeagleBone ARM Emmanuel Mayssat
