1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  <2013>  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  <2013>  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Subject: Re: RDB archive engine warning messages
To: "Konrad, Martin" <[email protected]>
Date: Tue, 17 Sep 2013 09:56:42 -0400
Hi:
The issue was simply a custom-build archive engine that didn't include the PVManager support for EPICS.
The ArchiveEngine.product lists these dependencies, amongst others: pvmanager, pvmanager.epics, pvmanager.sim, …
If you build an archive engine without pvmanager.epics, in fact no data sources at all, you get the error message
> …. uses the default data source but one was never set.
-Kay
On Sep 17, 2013, at 1:00 AM, "Konrad, Martin" <[email protected]> wrote:
> Hi,
>> java.lang.IllegalArgumentException: Channel emcvme100_fanspd1 uses
> Try using "epics://pvname" instead of "pvname". Maybe one of the CSS
> developers can give you a hint why epics is not the default (it usually
> should be).
> Martin
Re: RDB archive engine warning messages Konrad, Martin
Prev: RE: A little bit of history: Life before and after EPICS... Paul.gibbons
Next: RE: asyn support for EPICS timestamps and records with TSE=epicsTimeEventDeviceTime Mark Rivers
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  <2013>  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Prev: Re: RDB archive engine warning messages Konrad, Martin
Next: A little bit of history: Life before and after EPICS... Emmanuel Mayssat
