1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  <2013>  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  <2013>  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Subject: RE: PiezoSytemJena motorcontroller driver problems
To: "'Ivashkevych, Oksana'" <[email protected]>, "'[email protected]'" <[email protected]>
Cc: Tech-talk <[email protected]>
Date: Tue, 17 Sep 2013 20:37:44 +0000
The first step to debugging this is to turn on asynTrace in the underlying TCP/serial driver:
drvAsynIPPortConfigure("JenaSerial","10.0.10.5:4001")
# Add these lines for asynTrace debugging
asynSetTraceIOMask(“JenaSerial”,0,2)
asynSetTraceMask(“JenaSerial”,0,9)
You will then see all characters sent to and received from the device.  This will let you know if it is communicating at all.
You can also load an asyn record in the IOC, connect it to JenaSerial port, and send what you know to be a valid command and see if you get a response.
From: [email protected] [mailto:[email protected]] On Behalf Of Ivashkevych, Oksana
Sent: Tuesday, September 17, 2013 3:24 PM
To: '[email protected]'
Cc: Tech-talk
Subject: PiezoSytemJena motorcontroller driver problems
Hi Joe,
I have a PiezoSystemJena d-Drive, their latest product, and was hoping to use the existing driver written for EDS by you and recently updated (judging by time stamps in the source files), because it says in the manual that d-Drive is using EDS2 interface.
I was wondering if you/or someone else could comment on errors and if I can use this driver. It’s emphasized in many places that the driver communicates via GPIB.
My configuration: IOC is running on linux box, connected via Ethernet to NPort5450 MOXA switch and then to d-Drive via RS232.
st.cmd
"#!../../bin/linux-x86/PiezoSysJenaIoc
## You may have to change PiezoSysJenaIoc to something else ## everywhere it appears in this file
< envPaths
dbLoadDatabase("../../dbd/PiezoSysJenaIoc.dbd",0,0)
PiezoSysJenaIoc_registerRecordDeviceDriver(pdbbase)
# Piezosystem Jena EDS motor controller/driver setup parameters:
#     (1) maximum number of controllers in system
#     (2) maximum drives per controller
#     (3) motor task polling rate (min=1Hz, max=60Hz)
#drvPIJEDSdebug=1
#PIJEDSSetup(1, 2, 60)
PIJEDSSetup(1, 2, 10)
# Piezosystem Jena EDS controller/driver configuration parameters:
#     (1) controller being configured
#     (2) asyn port name (string)
#     (3) asyn address (GPIB)
PIJEDSConfig(0, "JenaSerial", 0)
## Load record instances
dbLoadTemplate("../../db/motor.substitutions","user=oksana")
iocInit()
## Start any sequence programs
#seq sncPiezoSysJenaIoc,"user=oksana"
motor.substitution
"file "../../db/motor.db"
pattern
{P,    N,       M,        DTYP,         C,      S,      DESC,           EGU,    DIR,    VELO,VBAS,  ACCL,          BDST,         BVEL,  BACC,   MRES,   PREC,   DHLM,   DLLM, INIT}
{jena:, 1,      "m$(N)",  "PIJEDS",      0,      0,      "motor $(N)",   um,     Pos,    2.,   0,     .2,             0,           0,    .2,      .001,   5,      100,    0,   ""}
{jena:, 2,      "m$(N)",  "PIJEDS",      0,      1,      "motor $(N)",   um,     Pos,    2.,   0,     .2,             0,           0,    .2,      .001,   5,      100,    0,   ""}
The output I have:
## You may have to change PiezoSysJenaIoc to something else ## everywhere it appears in this file < envPaths
epicsEnvSet("ARCH","linux-x86")
epicsEnvSet("IOC","iocPiezoSysJenaIoc")
epicsEnvSet("TOP","/epics/iocs/PiezoSysJena")
epicsEnvSet("EPICS_BASE","/usr/lib/epics")
#drvPIJEDSdebug=1
#dbLoadRecords("../../db/PiezoSysJenaIoc.db","user=oksana")
#dbLoadRecords("../../db/motor.db","user=oksana")
iocInit()
Starting iocInit
## EPICS R3.14.11-15 $R3-14-11$ $2009/08/28 18:47:36$ ## EPICS Base built Jan  8 2013 ############################################################################
drvStreamInit: Warning! STREAM_PROTOCOL_PATH not set. Defaults to "."
Illegal field value PV: jena:m1 motor_init_record_com(): card does not exist!
Illegal field value PV: jena:m2 motor_init_record_com(): card does not exist!
epics>
It seems to me that the error “Illegal field value PV: jena:m1 motor_init_record_com(): card does not exist!” may relate to PIJEDSConfig(0, "JenaSerial", 0), where asyn address is not correct. I also started to question whether I can use this driver…
Thanks for help,
Oksana
RE: PiezoSytemJena motorcontroller driver problems Ivashkevych, Oksana
Prev: PiezoSytemJena motorcontroller driver problems Ivashkevych, Oksana
Next: Installing epics.3.14.12.3 L. C. De Silva
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  <2013>  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Next: RE: PiezoSytemJena motorcontroller driver problems Ivashkevych, Oksana
