1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  <20132014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  <20132014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025
Subject: Re: LabView interface to EPICS
To: EPICS Tech-Talk <[email protected]>
Date: Thu, 19 Sep 2013 17:38:05 -0600
On 9/19/2013 2:26 PM, Emmanuel Mayssat wrote:
While investigating high-level framework for EPICS, I came across the
following page
http://digital.ni.com/public.nsf/allkb/BEF3C387D96E1A0C86257A3600508278
Is any one using LabView with EPICS?
What are the benefit of such a setup?
What are the drawbacks?
I use EPICS and LabVIEW together for several different projects. I have never used the setups discussed there.
From what I can think of quickly:
The benefits of such a setup are that NI should be able to support you easily if you have problems, and you can do all of your development with LabVIEW.
Existing LabVIEW programs can be quickly integrated into the control system.
The drawbacks are:
You do all of your development in LabVIEW.
You don't have a full EPICS database.
There are several other ways of interfacing between EPICS and LabVIEW.
The setup I've used both on cRIO (vxWorks) and win32, is to have a shared library that can store and retrieve information from memory. Then, I use a full EPICS IOC with device support that calls the shared library, and a LabVIEW program that also calls the shared library.
Advantages:
Fully functional EPICS IOC, including EPICS applications.
EPICS database development is done the same as always.
You can divide the workload between EPICS and LabVIEW however you want, sort of like interfacing EPICS with a PLC, but more flexible. Existing LabVIEW programs can be quickly integrated into the control system in a standard manor. No OS specific code (except for mutex and initialization code the shared library).
Disadvantages:
Must keep "hardware address list" and any enumerated types that are used in sync between EPICS and LabVIEW. On Win32, LabVIEW must start the EPICS IOC so that they run in the same process.
I use to different interface libraries, one is very specific to our industrial I/O project, and uses LabVIEW for FPGA development and passing data between device-specific EPICS device support and the FPGA.
see:
http://accelconf.web.cern.ch/accelconf/icalepcs2011/papers/thaaust01.pdf
The other uses very generic EPICS device support, and everything is either done by LabVIEW or the EPICS database. This is particularly useful for diagnostic devices.
> Is LabVIew only only to configure the FPGA?
> Or is LabVIew also used to control the FPGA (I/O), i.e. interact
> with PVs ?
There are always 2 LabVIEW programs, one generates the VHDL that runs on the FPGA. This code looks essentially like LabVIEW code for a CPU, but with a more restrictive set of functions (e.g., no dynamic arrays). Also, the technique to obtain the best performance is a bit different. For the industrial I/O a very simple LabVIEW program runs on the CPU that simply passes data between the FPGA and EPICS via a memory block allocated by the shared library. This program only knows about the data headers, and thus rarely need to be modified. For diagnostic devices, the LabVIEW code really does control functions of the kind that might otherwise require state notation language as well as analysis functions.
> If that's the case, do you use Labview GUIs that interact with
> multiple EPICS devices or IOCs?
> (That is can labview GUI be used as a replacement for edm/BOY/etc?)
We do not use LabVIEW GUIs in the control system, although it is possible to do. Using the EPICS client for LabVIEW that you mentioned, one could make a LabVIEW GUI that used channel access to interact with PVs. LabVIEW could be used to write custom applications where one might otherwise use Java or TCL/TK. This would not be a replacement for EDM/Boy/caQTdm, because you'd be changing your LabVIEW program each time you changed the GUI.
Scott Baily
AOT-IC, MS H820
Los Alamos National Laboratory
Los Alamos, NM 87545
ph: (505) 606-2260
Correspondence
RE: LabView interface to EPICS kathryn.baker
LabView interface to EPICS Emmanuel Mayssat
Prev: Re: LabView interface to EPICS Faucett, John A
Next: RE: LabView interface to EPICS kathryn.baker
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  <20132014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025
ANJ, 20 Apr 2015 Valid HTML 4.01! · Home · News · About · Base · Modules · Extensions · Distributions ·
