1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  <2013>  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  <2013>  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Subject: Re: LabView interface to EPICS
To: [email protected]
Date: Fri, 20 Sep 2013 13:48:08 +0200
Hi Emmanuel,
I have tried EPICS on cRIO but I am not satisfied with it. I do not like that neither alarms nor time stamps are forwarded to EPICS. LabView and EPICS communicate through a shared memory region which contains only values and is processed by both sides with independent cycle rates.
So when your EPICS record is scanned ".1 second", you get a new timestamp every 100 msec. But that does not mean that LabView has updated the value in the meantime. Not even dream of "I/O Intr" processing whenever LabView writes a new value.
Worse is that alarms are not handled. I looked into the LabView EPICS VI and found that in fact if it gets an error input, it skips writing into the shared memory! That means if something goes wrong on the LabView side (e.g broken hardware) EPICS happily reads the last good value and updates its timestamps. In my opinion the worst way you can deal with faults.
I reported these problems to NI a long time ago. But since they seen not able to do anything about this, I cancelled all NI related projects.
Dirk
On 19.09.2013 22:26, Emmanuel Mayssat wrote:
All,
While investigating high-level framework for EPICS, I came across the following page
http://digital.ni.com/public.nsf/allkb/BEF3C387D96E1A0C86257A3600508278
Is any one using LabView with EPICS?
What are the benefit of such a setup?
What are the drawbacks?
Emmanuel
LabView interface to EPICS Emmanuel Mayssat
Prev: RE: LabView interface to EPICS kathryn.baker
Next: Re: Generating a loadable module for cexp (epics 3.14.12.3) Till Straumann
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  <2013>  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Next: Generating a loadable module for cexp (epics 3.14.12.3) Sue Witherspoon
