1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  <2013>  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  <2013>  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Subject: Re: Version strings to track not only EPICS BASE but other IOC modules/components
To: [email protected]
Date: Tue, 24 Sep 2013 12:04:16 -0400
For some of my projects I compile in a VCS revision number (for us Mercurial and/or Git) which appears in a stringin record. This has proven useful in keeping track of my ~40 timing VME crates.
A (poor) example can be found in the mrfioc2 module. I say poor because it is regenerating a C header file regardless of whether this is needed, which triggers a recompile and relink every time make is invoked.
I too would like to see a standard solution.
Michael
http://epics.hg.sourceforge.net/hgweb/epics/mrfioc2/file/9f6e261d3ea9/mrfCommon/src/Makefile#l94
http://epics.hg.sourceforge.net/hgweb/epics/mrfioc2/file/9f6e261d3ea9/mrfCommon/src/mrf/version.h
On 09/24/2013 10:25 AM, Williams Jr., Ernest L. wrote:
Hi everyone,
How might one use the same scheme to supply a version string to reflect the version of a software module?
Does EPICS Toolkit support this for Driver/Device Support?
Would also be nice to have a version string supported for IOC applications as well.
Can this be done in a standardized way such as dbior()?
For example, EPICS BASE uses:
"$EPICS_BASE_RELEASE/configure/CONFIG_SITE"
Variable NAME = EPICS_SITE_VERSION
Then at the ioc shell  coreRelease() will print out the version string.
So, for an EPICS module maybe:
<moduleName>Release()
For an IOC Application:
<iocAppName>Release()
This would be very useful and can also be place in a PV :)
Anyone already doing this?  If so, can we get it standardized as part of the EPICS BASE and templates?
Cheers,
Ernest
Version strings to track not only EPICS BASE but other IOC modules/components Williams Jr., Ernest L.
Prev: Re: Version strings to track not only EPICS BASE but other IOC modules/components Rod Nussbaumer
Next: Channel Access in Erlang paper at ICALEPCS 2013 Dennis Nicklaus
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  <2013>  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
