1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  <2013>  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  <2013>  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Subject: Re: procServ and sseq
To: "Hartman, Steven M." <[email protected]>
Cc: "Taylor, Ian" <[email protected]>, Tech Talk <[email protected]>
Date: Sat, 28 Sep 2013 14:16:27 +0100
Hi Steven,
That's an interesting point.  In both cases where this fails, the VME IOCs get initialized by epics (username),
but all of them are loaded from /home/controls.  My soft IOCs are all from epics.
I had a similar problem with things like the channel archiver.   My /etc/rc.local never worked to start the
archiver because the archiver was built in /home/archiver and the user was epics.
I'll let you know (for the techtalk record) when I try again.
Pierrick
On 09/28/2013 02:07 PM, Hartman, Steven M. wrote:
Is the Linux IOC running under the same user ID when using procServ as when running from the command line? If not, access security may be blocking writes.
"Whether you think you can or think you can't, either way, you are correct" -- Henry Ford
_______________________________________________________________
Pierrick Hanlet
IIT/Fermilab
+44-(0)1235-44-5550 (RAL)
+1-630-840-5555 (FNAL)
+1-312-567-5745 (IIT)
+1-630-697-8758/+44-(0)79-48-860-197 (US/UK mobile)
RE: procServ and sseq Hartman, Steven M.
Prev: RE: procServ and sseq Hartman, Steven M.
Next: A question regarding sequencer compatibility Benjamin Franksen
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  <2013>  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
