Hi Michael,
On 09/30/2013 10:54 AM, Michael Johnson wrote:
We have a new unix-side process at JLab with some interesting knowledge,
and we want to push this knowledge out to an interface. There will be a
lot of text and long lists - way past the EPICS String record
40-character limit.
Please offer any advice or pointers you have:
1) What EDM widgets are favored for this kind of large text output?
2) How does one push data to EDM when PVs do not fit requirements? File
I/O? IPC?
I believe all EPICS OPIs now support long strings, which are just
character arrays containing text (which in most cases should be
nil-terminated, but the client must not assume that). MEDM and EDM
certainly allow you to point a text widget to a waveform record or other
array field (the aSub record is also good for this) that is configured
to hold CHARs. In the case of MEDM you do have to configure the widget
display Format to "string", I'm not sure about EDM. Note that the
caput/caget/camonitor programs that come with base support long strings
with a -S option.
I can't tell you how the widget actually interprets the text, hopefully
EDM supports wrapping and line breaks, but I have no idea if it actually
does (I don't think MEDM can but I haven't tried it). It would seem
like someone might even be able to write a widget that could handle a
pluggable formatter to accept Markdown or even HTML, but I'm not sure if
it would really be worth doing that.
HTH,
- Andrew
Advertising may be described as the science of arresting the human
intelligence long enough to get money from it. -- Stephen Leacock
- RE: Text in EDM Sinclair, John William
- Text in EDM Michael Johnson
<2013>
2025
<2013>
2025
