1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  <2013>  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  <2013>  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Subject: Re: A question regarding sequencer compatibility
To: Benjamin Franksen <[email protected]>
Cc: [email protected]
Date: Tue, 01 Oct 2013 12:19:58 -0500
On 10/1/13 9:48 AM, Benjamin Franksen wrote:
> My current plan is therefore to give a compile time error if pv
> functions are called with multi-PV arrays, as they do not properly
> support them anyway. This means the compiler helps you by pointing to
> the location in your source code where a change is needed. Either you
> append "[0]" to the variable if that is actually the intention. Or
> it's not, and as a result a few errors will be uncovered and wouldn't
> that be nice?[*]
> What to do with pvPutComplete? It is the only function that properly
> supports multi-PV arrays. I think I will remove this feature so that
> it behaves in manner consistent with pvGetComplete, and then add a new
> function that implements the more general behaviour. Again, this means
> you might have to slightly change your program but the compiler will
> help you in figuring out what to do.
> BTW, on the subject of how to name the new functions (no bike-shedding
> ensued, are you all asleep?) I am currently in favour of using pural
> form i.e. pvGets, pvPuts, pvGetsComplete, etc. I don't like pvGetArray
> since (1) the normal pvGet works perfectly fine with arrays (only
> not with multi-PV arrays) and (2) the new function will work with
> single-PV variables, too.
Hi, Ben.
I'm OK with your proposed changes, and I agree with your reasoning for
favoring the plural naming over the "array" naming.
> And now to another issue: Currently, the timeout for synchronous pvGet
> and pvPut is hard-coded to 10 seconds. Adding an extra (optional)
> argument to specify a different timout has been on my wish-list
> for a long time. This is now implemented (in the 2.2 branch) but
> again an issue of compatibility comes up, though in this case it
> does not concern SNL code proper (adding an extra DEFAULT_TIMEOUT
> argument can be done automatically by the compiler). However, escaped
> C code that calls seq_Pv{Put,Get} will have to be changed to add this
> argument. Note that here, too, the compiler (the C compiler in this
> case) poinpoints the location of the problem for you.
> I am in favour of making this change in version 2.2, but if it turns
> out to hurt people too much I am willing to restrict the change to the
> new pvGets and pvPuts.
I'm OK with this change being made in 2.2.  However, why couldn't
you use varargs to avoid needing to change escaped C code calls to
seq_Pv{Put,Get}?  Or are you avoiding that to keep it clean and simple?
Lewis
Re: A question regarding sequencer compatibility Benjamin Franksen
Prev: RE: A question regarding sequencer compatibility Mooney, Tim M.
Next: RE: A little bit of history: Life before and after EPICS... Emmanuel Mayssat
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  <2013>  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Prev: Re: A question regarding sequencer compatibility Benjamin Franksen
Next: Re: A question regarding sequencer compatibility Benjamin Franksen
