1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  <2013>  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  <2013>  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Subject: Re: Connecting EDM screens to multiple soft IOCs on the same machine on a separate subnet.
To: Alan Greer <[email protected]>
Cc: [email protected]
Date: Wed, 16 Oct 2013 10:23:49 -0500
Hi Alan,
On 10/16/2013 09:01 AM, Alan Greer wrote:
I have a headless server (serv01) running two soft IOCs (IOC-01 and IOC-02).
I have another machine on a separate subnet that runs the EDM GUI
applications for those IOCs.
caRepeater is running on serv01.
caRepeater is only used by CA clients running on the same machine, so that won't help this situation at all.
I hope I have explained this with enough detail, can anyone help me so
that the connections to IOC-01 are not lost(?) when running up IOC-02.
Kay's explanation of the problem is correct, but there are alternative solutions to running a CA gateway.
1. You could run a CA Nameserver in the GUI subnet which knows about the IOCs and responds to search requests; in this case you would *not* set the EPICS_CA_ADDR_LIST variables. This is almost equivalent to running a CA Gateway, but is slightly more robust in that if the Nameserver process dies it wouldn't kill any existing connections.
2. If you have access to a machine with a network interface on both subnets you could also try running a program on it called UDP Broadcast Packet Relay https://www.joachim-breitner.de/udp-broadcast-relay/ which forwards broadcast packets between subnets. You would probably have to run it twice, once on port 5064 and once on 5065; the first one will forward CA search requests between the subnets, and the second sends the CA beacons. If you do have success with this please let us know, we use it here at the APS for forwarding timing UDP packets but not for CA.
- Andrew
Advertising may be described as the science of arresting the human
intelligence long enough to get money from it. -- Stephen Leacock
Re: Connecting EDM screens to multiple soft IOCs on the same machine on a separate subnet. Alan Greer
Prev: Re: Connecting EDM screens to multiple soft IOCs on the same machine on a separate subnet. Kasemir, Kay
Next: Re: how to put value to other record in subroutine record Andrew Johnson
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  <2013>  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Next: Re: Connecting EDM screens to multiple soft IOCs on the same machine on a separate subnet. Alan Greer
