Hi Dirk,
I rebuilded the vxWorks including C++, and the problem has been resolved.
Thank you very much!
Mi Qingru
-----原始邮件-----
Sent: Wednesday, October 16, 2013 5:13 PM
To: [email protected]
Subject: Re: Problem as loading munch to vxWorks/mvme5500
On 16.10.2013 10:32, Mi Qingru wrote:
The problem has ocuured during loading munch as apachment showing.
The vxWorks is 5.5. The Linux is Scientist Linux4.4. The base is
3.14.12.3. And the aysn is 4.21 and the motor is 6-7-1.
Mi Qingru
If you need to set sysCplusEnable=1, there is probably something wrong
with your C++ setup. The file usrExtra.c contains:
#if defined (INCLUDE_CPLUS) || defined (INCLUDE_CPLUS_MIN)
BOOL sysCplusEnable = TRUE; /* TRUE = enable C++ support */
#else
BOOL sysCplusEnable = FALSE;
#endif
So if you build vxWorks with C++, the variable should already be 1.
Dirk
- Problem as loading munch to vxWorks/mvme5500 Mi Qingru
- Re: Problem as loading munch to vxWorks/mvme5500 Dirk Zimoch
Electronic & Control Systems Engineer Job Postings at W.M. Keck Observatory Jimmy Johnson
Re: asynError IOC message Vikram Bhagat
<2013>
<2013>
