1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  <2013>  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  <2013>  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Subject: Re: How to Read Multiple Values using StreamDevice with array_in
To: Dirk Zimoch <[email protected]>, "[email protected]" <[email protected]>
Date: Mon, 21 Oct 2013 11:22:25 +0300
Hello Dirk,
I've done what you suggested. But I can't read passive records 2 values.
epics> 2013/10/21 11:16:51.892 192.168.1.198:9001 write 7
MEASC\r\n
2013/10/21 11:16:51.906 192.168.1.198:9001 read 8
025 026
2013/10/21 11:16:51.914 192.168.1.198:9001 read 8
027 025
2013/10/21 11:16:51.925 192.168.1.198:9001 read 7
025 026
2013/10/21 11:16:52.025445 thermoIPConn M:TEMP1: Timeout after reading 23 bytes "... 026 027 025 025 026"
[root@105 ipThermo]# caput M:TEMP1 1
Old : M:TEMP1                        0
New : M:TEMP1                        1
[root@105 ipThermo]# caget M:TEMP1
M:TEMP1                        26
[root@105 ipThermo]# caget M:TEMP2
M:TEMP2                        0
[root@105 ipThermo]# caget M:TEMP3
M:TEMP3                        0
[root@105 ipThermo]# caget M:TEMP4
M:TEMP4                        0
[root@105 ipThermo]# caget M:TEMP5
M:TEMP5                        0
[root@105 ipThermo]# caget M:TEMP6
M:TEMP6                        0
I defined DTYP as "Raw Soft Channel".
Yasemin
Hello Yasemin
On 07.10.2013 10:03, Yasemin Barutçu wrote:
Hello,
I have a self-produced thermocouple and I connect to this device by RS 232.
I want to read 6 different integers when I send "MEASC" command to the
device.
in thermo.proto file, if I define %s, I can read all data by stringin.
MEASC{
     out "MEASC";
     in "%s";
Example:
2013/10/07 10:59:53.633 192.168.1.198:9001 <http://192.168.1.198:9001>
write 6
MEASC\n
2013/10/07 10:59:53.647 192.168.1.198:9001 <http://192.168.1.198:9001>
read 8
029 030 029 028 028 028
But I want to take all 6 datas in integer format. I search the
streamdevice documentation and I found the following line.
There several possibilities to do this.
MEASC{
     out "MEASC";
     array_in {separator=" "; in "%d";}
But it doesn't work. I got the following error.
No that does not work. What you wanted to do is:
MEASC{
    separator=" ";
    out "MEASC";
    in "%d";
But then you get an array of 6 values. Maybe you want to have the 6 values in separate records. You can do this using redirected input:
MEASC{
    out "MEASC";
in "%d %(\1:TEMP2)d %(\1:TEMP3)d %(\1:TEMP4)d %(\1:TEMP5)d %(\1:TEMP6)d";
Called from a record like this:
record (ai, "$(P):TEMP1") {
    field (DTYP, "stream)
    field (INP,  "@thermo.proto MEASC($(P)) $(PORT)")
And 5 passive records like this:
record (ai, "$(P):TEMP2") {
record (ai, "$(P):TEMP3") {
record (ai, "$(P):TEMP4") {
record (ai, "$(P):TEMP5") {
Note that the 5 passive records have no "stream" support (in fact they use "Soft Channel" or if you wish you can use "Raw Soft Channel").
Dirk
Re: How to Read Multiple Values using StreamDevice with array_in Dirk Zimoch
Prev: AreaDetector: using attributes to set file number Emma Shepherd
Next: Re: How to Read Multiple Values using StreamDevice with array_in Dirk Zimoch
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  <2013>  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Prev: How to Read Multiple Values using StreamDevice with array_in Yasemin Barutçu
