1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  <20132014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  <20132014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024
Subject: EPICS V4.3.0 Release
To: EPICS tech-talk <[email protected]>
Date: Fri, 25 Oct 2013 11:01:06 -0500
The EPICS V4 Working Group are pleased to announce the final release of the latest version of our EPICS V4 software, version 4.3.0.
This release concentrates on making it easy to work with the existing features of EPICS V4, while using EPICS Base 3.14 IOCs as the control system foundation. It adds two new interfaces to IOC data, via either Channel Access or pvAccess, enabling many options for configuring a high performance and highly functional scientific instrument control environment. Other features include an easy to use API, improved command line programs and several example programs.
Two implementations are provided for the main modules, one written in C++ and the other in Java. The C++ implementation compiles for recent versions of Linux, MacOS, VxWorks (both 5.5.x and 6.x) and RTEMS, and requires an installation of EPICS Base 3.14. The Java implementation requires Java 6 or later, although Java 7 is recommended.
Downloads of both implementations are available from SourceForge:
    https://sourceforge.net/projects/epics-pvdata/files/4.3.0/
More technical details and documentation can be found through the EPICS V4 project website:
    http://epics-pvdata.sourceforge.net/index.html
Questions and discussion about the EPICS V4 should be directed to this EPICS tech-talk mailing list.
Many thanks to everyone who helped develop and test this version of the software.
- Andrew Johnson and Greg White, V4 WG chairs
Advertising may be described as the science of arresting the human
intelligence long enough to get money from it. -- Stephen Leacock
Re: EPICS V4.3.0 Release Kevin Peterson
Prev: Agilent E3633A? Pearson, Matthew R.
Next: Re: EPICS V4.3.0 Release Kevin Peterson
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  <20132014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024
ANJ, 20 Apr 2015 Valid HTML 4.01! · Home · News · About · Base · Modules · Extensions · Distributions · Download ·
