Hi Ralph,
I’m confused. You said:
> Setting EPICS_CA_AUTO_ADDRESS=NO suppresses the UDP broadcast
But what if I set
EPICS_CA_AUTO_ADDR_LIST=NO
EPICS_CA_ADDR_LIST = 164.54.160.255
I do this to restrict EPICS_CA_ADDR_LIST to the broadcast address of one of my NICs. Don’t I still get UDP broadcasts?
On Behalf Of Ralph Lange
Sent: Thursday, October 31, 2013 1:14 PM
To: EPICS Tech-Talk
Subject: Re: Channel access over wireless?
On 31.10.2013 18:55, Emmanuel Mayssat wrote:
I am contemplating a project which requires wireless communication.
I would like to have telemetry information on a control station.
The network link specification is: range 1 mile at 250Kbps
Latency could definitely be an issue (measurement needed at this point)
I could potentially have several 250Kpbs links (not sure whether they can be 'trunked' together)
The remote device could run an IOC (I need something like a 'fast' sequencer for sure)
Between local OPI and remote IOC, I can use any communication protocol I want
Classic architecture:
local OPI ---- (CA over wireless) --- remote IOC
is there a way for an OPI to bypass the UDP discovery process and force connection to a specific IP addres/port?
Setting EPICS_CA_ADDRESS_LIST restricts discovery traffic to a list of IP/port addresses
Setting EPICS_CA_NAME_SERVERS uses TCP for discovery traffic to a list of IP/port addresses
Setting both
EPICS_CA_NAME_SERVERS=your.destination.ip.address:port
will run Channel Access exclusively to that server/port, using TCP for name resolution and data.
You could e.g. use this to tunnel CA through SSH.
You can find more information in the Channel Access Reference Manual.
HTH,
~Ralph
- Re: Channel access over wireless? Ralph Lange
- Channel access over wireless? Emmanuel Mayssat
RE: Channel access over wireless? Hill, Jeff
<2013>
2025
<2013>
2025
ANJ, 20 Apr 2015 |
Home
News
About
Base
Modules
Extensions
Distributions
Download
Search
IRMIS
Talk
Documents
Links
Licensing
