1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  <20132014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  <20132014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025
Subject: Re: Newport XPS-Q8 and Motor Record - RV120HAHL stage
To: Mark Rivers <[email protected]>, "'Tonia Batten'" <[email protected]>, "[email protected]" <[email protected]>
Date: Mon, 4 Nov 2013 09:52:10 -0600
On 11/1/13 4:53 PM, Mark Rivers wrote:
> You can determine what value of stepSize the driver is acutall using by
> typing the following command:
> asynReport 10 XPS1
I have to use 'dbior' instead of 'asynReport' to see the stepSize info
when the old XPS driver (drvXPSAsyn.c) is used:
vme> dbior "motorXPS", 1
Driver: motorXPS
Controller 0 firmware version:
Axis 0 name:GROUP1.POSITIONER
   pollSocket:0, moveSocket:1
   axisStatus:12
   stepSize:0.0001
Axis 1 name:GROUP2.POSITIONER
   pollSocket:0, moveSocket:2
   axisStatus:12
   stepSize:0.0001
Axis 2 name:GROUP3.POSITIONER
   pollSocket:0, moveSocket:3
   axisStatus:12
   stepSize:0.0001
Axis 3 name:GROUP4.POSITIONER
   pollSocket:0, moveSocket:4
   axisStatus:12
   stepSize:0.0001
Axis 4 name:GROUP5.POSITIONER
   pollSocket:0, moveSocket:5
   axisStatus:12
   stepSize:0.0001
Axis 5 name:GROUP6.POSITIONER
   pollSocket:0, moveSocket:6
   axisStatus:12
   stepSize:0.0001
Axis 6 name:GROUP7.POSITIONER
   pollSocket:0, moveSocket:7
   axisStatus:12
   stepSize:0.01
Axis 7 name:GROUP8.POSITIONER
   pollSocket:0, moveSocket:8
   axisStatus:12
   stepSize:0.0001
If iocsh is being used, the syntax is more relaxed:
epics> dbior motorXPS 1
Kevin
Newport XPS-Q8 and Motor Record - RV120HAHL stage Tonia Batten
RE: Newport XPS-Q8 and Motor Record - RV120HAHL stage Mark Rivers
Prev: RE: Newport XPS-Q8 and Motor Record - RV120HAHL stage Tonia Batten
Next: RE: Newport XPS-Q8 and Motor Record - RV120HAHL stage Mark Rivers
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  <20132014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025
Prev: RE: Newport XPS-Q8 and Motor Record - RV120HAHL stage Mark Rivers
Next: Device support for Agilent 34401A Peter . Mueller
ANJ, 20 Apr 2015 Valid HTML 4.01! · Home · News · About · Base · Modules · Extensions · Distributions ·
