1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  <20132014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  <20132014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024
Subject: Re: CSS EPICS PV connectivity issue
To: Juan Manuel Lozano <[email protected]>
Cc: [email protected]
Date: Thu, 21 Nov 2013 12:52:45 -0600
On 11/21/2013 12:24 PM, Juan Manuel Lozano wrote:
  * IOC is in a virtual machine running Linux (192.168.1.45)
  * CSS is in the host machine, running Windows 7 (192.168.1.33)
  * Both systems, as you can see, share the same subnet, which is
    192.168.1.0/24
If I configure CSS with addr_list to 192.168.1.45 all works perfectly,
but IOC's IP is dynamic so I want to force CSS to discover PVs. When I
turn on auto_addr_list in CSS and leave addr_list empty, it doesn't
connect. If I put 192.168.1.0 in addr_list field doesn't connect neither.
Check that both machines share the same broadcast IP address, and that they don't have a firewall blocking TCP or UDP traffic between them on ports 5064 and 5065.
I would like to probe caget as you suggested, but I don't know if this
is possible in Windows 7
You should be able to run caget from a command window in Windows 7, I'm not sure what your asking here. Does caget manage to connect when you run it directly on the linux machine?
- Andrew
Advertising may be described as the science of arresting the human
intelligence long enough to get money from it. -- Stephen Leacock
CSS EPICS PV connectivity issue Juan Manuel Lozano
Prev: Re: How to archive PVs in epics which are deployed in labview Rod Nussbaumer
Next: Re: CSS EPICS PV connectivity issue Ralph Lange
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  <20132014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024
Prev: CSS EPICS PV connectivity issue Juan Manuel Lozano
ANJ, 20 Apr 2015 Valid HTML 4.01! · Home · News · About · Base · Modules · Extensions · Distributions · Download ·
