Hello.
Thank you Ralph, Andrew and Kasemir for your replies. All was my
fault because and a beginner... 192.168.1.255 and auto_addr_list
turned on is working perfectly!
Thank you so much again
El 21/11/2013 20:03, Ralph Lange
escribió:
Hi.
P.D: I'm not a subscriber but this e-mail is a reply to this
tech-talk http://www.aps.anl.gov/epics/tech-talk/2011/msg01405.php
If you can publish it anyway I'll be very grateful
I have the same problem. I'll describe my system:
- IOC is in a virtual machine running Linux (192.168.1.45)
- CSS is in the host machine, running Windows 7
(192.168.1.33)
- Both systems, as you can see, share the same subnet, which
is 192.168.1.0/24
If I configure CSS with addr_list to 192.168.1.45 all works
perfectly, but IOC's IP is dynamic so I want to force CSS to
discover PVs. When I turn on auto_addr_list in CSS and leave
addr_list empty, it doesn't connect. If I put 192.168.1.0 in
addr_list field doesn't connect neither.
Have you tried setting the addr_list field to the broadcast
address of your network, i.e. 192.168.1.255?
~Ralph
Juan Manuel Lozano Contreras
Tlf: (+34) 650 24 66 10
E-mail: [email protected]
Parque Empresarial La Raya - PCTH
- Despacho 3
Calle Industria 59, 21110
Aljaraque, Huelva, España
- CSS EPICS PV connectivity issue Juan Manuel Lozano
- Re: CSS EPICS PV connectivity issue Ralph Lange
RE: Why should I care about breakpoint table monotonicity? Hartman, Steven M.
RE: areaDetector for PGR Flea3 GigE camera tom.cobb
<2013>
Why should I care about breakpoint table monotonicity? Emmanuel Mayssat
<2013>
ANJ, 20 Apr 2015 |
Home
News
About
Base
Modules
Extensions
Distributions
Download
Search
EPICS V4
IRMIS
Talk
Bugs
Documents
Links
Licensing
