Subject: |
Re: Why should I care about breakpoint table monotonicity? |
Andrew Johnson <[email protected]> |
To: |
Date: |
Fri, 22 Nov 2013 12:01:19 -0600 |
On 11/22/2013 11:47 AM, Emmanuel Mayssat wrote:
What surprises me even more is that ***at compilation time*** dbExpand
(!?!?) check for the monotonicity.
In 3.14.x the same code that loads DBD files into the IOC is used in the
dbExpand program, so it does the same checking. You can give dbExpand a
-b flag to disable the monotonicity check though. Put
DBEXPAND += -b
into your Makefile to add that flag to all calls to dbExpand (there is a
USR_DBDFLAGS variable, but it also gets use for other programs which
won't understand the -b flag so you probably don't want to use that).
HTH,
- Andrew
Advertising may be described as the science of arresting the human
intelligence long enough to get money from it. -- Stephen Leacock
- RE: Why should I care about breakpoint table monotonicity? Emmanuel Mayssat
- RE: Why should I care about breakpoint table monotonicity? Hartman, Steven M.
Re: EpicsSharp issues Alain Bertrand
<2013>
<2013>
