But I was using alh_1_24 for Alarm handler for base 3.14.12.3. I had created extension directory into which I copied the content of alh_1_24 and renamed it as src as described in http://www.aps.anl.gov/epics/extensions/config/index.php When I compiled it (by make on src), it got terminated ...fatal error: Xm/Xm.h :No such File or directory Thanks & Regards Swati Soni
The optional ALARMHANDLER environment variable should specify the directory where your Alarm Handler input configuration files reside and where the Alarm Handler output log files should be written. The PATH environment variable should include the directory of the alarm handler executable. Janet From: [email protected] [[email protected]] on behalf of Swati Soni2 [[email protected]] Sent: Tuesday, November 26, 2013 6:04 AM To: [email protected] Subject: Fw: Alarm Handler Hi I am using EPICS 3.14.12.3 on fedora..I want to install Alarm handler extension. Can anyone tell me how to set environment ? I had used setenv ALARMHANDLER /<path name of alh1_3_31> Bt it throws error commnad not found....Is there any other command to get it installed?? I am following http://www.aps.anl.gov/epics/EpicsDocumentation/ExtensionsManuals/AlarmHandler/alhUserGuide-1.2.33/ALHUserGuide.html Thanks & Regards Swati Soni =====-----=====-----===== Notice: The information contained in this e-mail message and/or attachments to it may contain confidential or privileged information. If you are not the intended recipient, any dissemination, use, review, distribution, printing or copying of the information contained in this e-mail message and/or attachments to it are strictly prohibited. If you have received this communication in error, please notify us by reply e-mail or telephone and immediately and permanently delete the message and any attachments. Thank you
ANJ, 20 Apr 2015 |
![]() · Search · EPICS V4 · IRMIS · Talk · Bugs · Documents · Links · Licensing · |
