1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  <2013>  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  <2013>  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Subject: RES: Error with Asyn and rpcgen
From: Lucas Jose Monteiro Carvalho <[email protected]>
To: Hugo Slepicka <[email protected]>
Date: Thu, 28 Nov 2013 12:31:40 -0200
Thanks Hugo, it works!
Lucas José Monteiro Carvalho
Control Group
Brazilian Synchrotron Light Laboratory
[email protected]<mailto:[email protected]>
+55 19 935121197
De: Hugo Slepicka [[email protected]]
Enviado: quarta-feira, 27 de novembro de 2013 16:05
Para: Lucas Jose Monteiro Carvalho
Cc: [email protected]
Assunto: Re: Error with Asyn and rpcgen
Hi Lucas,
I've found the package that you need to install in order to get rpcgen on beaglebone black.
The command is: opkg install glibc-utils
Bests,
Hugo
Hugo Henrique Slepicka
Engenheiro de Computação
SOL - Software de Operação das Linhas de Luz
LNLS - Laboratório Nacional de Luz Síncrotron
CNPEM - Centro Nacional de Pesquisa em Energia e Materiais
5913 - [email protected]<mailto:[email protected]>
www.lnls.br<http://www.lnls.br>
On Wed, Nov 27, 2013 at 3:32 PM, Lucas Jose Monteiro Carvalho <[email protected]<mailto:[email protected]>> wrote:
Hello, all.
I'm trying to compile Asyn 4.21 in a Beaglebone Black, but I got this error:
cp ../vxi11/vxi11core.rpcl .
rpcgen  vxi11core.rpcl
make[2]: rpcgen: Command not found
make[2]: *** [vxi11core_xdr.c] Error 127
make[2]: Leaving directory `/home/root/asyn/asyn/O.linux-arm'
make[1]: *** [install.linux-arm] Error 2
make[1]: Leaving directory `/home/root/asyn/asyn'
make: *** [asyn.install] Error 2
How can I fix this error? The opkg does not install rpcgen.
Thanks in advance,
Control Group
+55 19 935121197
Error with Asyn and rpcgen Lucas Jose Monteiro Carvalho
Re: Error with Asyn and rpcgen Hugo Slepicka
Prev: Re: Increasing scan rate to 10 kHz Benjamin Franksen
Next: All Pvs disconnected Julio Calvo
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  <2013>  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Prev: Re: Error with Asyn and rpcgen Hugo Slepicka
