1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  <2013>  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  <2013>  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Subject: which time/timestamp format to use for an EPICS facility?
To: EPICS Tech Talk <[email protected]>
Date: Tue, 3 Dec 2013 18:34:44 +0000
I'm working on the Global Timing System for FRIB. In this context I'm
wondering which time we should use for the whole facility. This question
  is about two things:
1. the time we want to use (something like local time, UTC, GPS time, TAI)
2. the representation of this time in a computer/FPGA/PLC/IOC/...
We still have a few years until FRIB will be in operation so we have the
opportunity to do things right from the beginning. I'd appreciate to
hear your thoughts about this topic since this seems to be a critical
design decision.
Regarding 1.:
In my eyes using daylight savings time is calling for trouble. Think
about an archiver that has to deal with gaps and getting samples for the
same hour twice. This is also about all the clients, scripts, and
operators that need to keep this in mind.
Using local (winter) time might be ok for the EPICS environment itself.
But it will be difficult to tell which of two firmware files generated
in different time zones is newer. And we probably do want to use the
same time for everything...
UTC solves these problems but has leap seconds. Unfortunately they are
only known a few months in advance which makes it difficult to build
them into computers not to mention a distributed control system.
If you want to get rid of leap seconds you can go for GPS time [1] or
International Atomic Time (TAI, [2]). Both do not have leap seconds and
thus slowly diverge from UTC (right now GPST = UTC + 16 s, TAI = UTC +
35 s).
TAI and GPST seem to be ideal to me for an accelerator control system.
They can be easily derived with high precision from GPS clocks. The
downside is that operators have to work with different times on their
GUI and their watch.
Regarding 2:
It seems like most of our current systems use POSIX timestamps or EPICS
timestamps for internal representation of time. Unfortunately they both
come with several issues:
1. 32 bit POSIX timestamps will overflow in 2038 [3] which is within the
planned life time of FRIB. EPICS timestamps are very similar but use a
different epoch and thus can be used until 2058.
2. POSIX as well as EPICS timestamps do not provide a representation for
leap seconds (although the clock is running on UTC by definition). Thus
one of the following ugly work-arounds is needed:
a) Wait for the clock to be off one second and compensate for that using
NTP after it happened. Not acceptable since every machine corrects at
its own speed.
b) Make the preceding second last two seconds by stopping the clock for
one second. This is done by systems running recent NTP daemons and
kernels. Since these systems do not have a correct time during leap
seconds they cheat by simply providing _some_ time that they think
_might_ make sense. There is no guarantee that you will get the same
timestamp at the same time on multiple machines (even if they run the
same OS!). We also have to make sure all our software can handle twice
as much samples per second etc. Probably not acceptable.
c) Start some time earlier and stretch seconds a little ("smear" out the
leap second). This approach is used by Google for their servers [4]. If
implemented in the right way this should happen synchronously on all
machines. This probably cannot be done with PLCs.
3. Leap seconds make it much more difficult to calculate the time
elapsed between two timestamps (which is what nuclear physicists usually
do when working with their data). We need to make sure we have correct
leap-second data available for all software that calculates time
differences. This seems to be practically impossible to me.
It seems to be a _really_ big task to determine if all system on our
accelerator network handle leap seconds correctly or even the same way.
My proposal/solution:
Use TAI for the whole accelerator network including all EPICS IOCs,
PLCs, control room PCs etc. Force operators, users, logbooks etc. to use
TAI. Keep using local time for office PCs and data center equipment.
Use TAI64 timestamps [5] where possible. Convert to POSIX/EPICS
timestamps where needed. The latter should work smoothly until 2038
since TAI has no leap seconds. Control System Studio's PVManager already
uses 64 bit timestamps internally. Since most state-of-the-art CSS
applications use PVManager I don't see any fundamental problems on this end.
To use TAI we have to run our own PTP and NTP servers and prevent the
latter from announcing leap seconds. We need to block access to NTP
servers outside of the accelerator network.
There are still some open questions:
What effects do different timestamps have on network connections that
cross the office/accelerator network boundary? Some things that come to
my mind:
1. Encrypted connections might cause problems because system time is
used to protect against replay attacks. Usually a time difference of one
or two minutes should be acceptable, though.
2. Functions of GUI software sending the current system time via the
network might result in undesired behavior if used from the office
network. E.g. Control System Studio Archive Viewer's "-10 minutes to
now" probably will not work as expected.
What else do we need to keep in mind? Can anyone provide some experience
with running a control system on a time that is different from local
time/UTC?
Thanks for reading this long one!
Martin
[1]
http://en.wikipedia.org/w/index.php?title=Global_Positioning_System&oldid=584232968#Timekeeping
[2]
http://en.wikipedia.org/w/index.php?title=International_Atomic_Time&oldid=581789205
[3] http://en.wikipedia.org/w/index.php?title=Unix_time&oldid=583201834
[4] http://www.aps.anl.gov/epics/tech-talk/2011/msg01579.php
[5] http://cr.yp.to/libtai/tai64.html
Martin Konrad
Control System Engineer
Facility for Rare Isotope Beams
Michigan State University
640 South Shaw Lane
East Lansing, MI 48824-1321, USA
Tel. 517-908-7253
Email: [email protected]
RE: which time/timestamp format to use for an EPICS facility? Emmanuel Mayssat
Prev: RE: EpicsSharp issues Christopher J. Pendleton
Next: RE: EpicsSharp issues Christopher J. Pendleton
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  <2013>  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Prev: RE: Microlab 500 Syringe Pump Jemian, Pete R.
Next: RE: which time/timestamp format to use for an EPICS facility? Emmanuel Mayssat
