1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  <2013>  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  <2013>  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Subject: Re: Error associated to building asyn4-21
To: "L. C. De Silva" <[email protected]>
Date: Wed, 11 Dec 2013 12:15:08 -0800
As a first step, make sure whatever configuration file there is has the correct paths in it. It's been a bit since I last installed asyn, but that is always my first step when dealing with epics and it's various parts.
James
Sent from my iPhone
> On Dec 11, 2013, at 12:04 PM, "L. C. De Silva" <[email protected]> wrote:
> Dear all,
> I get the following error message during the process of building asyn4-21 on my linux 32-bit machine.
> make[3]: Entering directory `/home/sysuser/epics.3.14.12.1/soft/modules/asyn4-21/testApp/src/O.linux-x86'
> echo "../O.Common/test.dbd : ../Makefile" >> test.dbd.d
> Expanding dbd
> /home/sysuser/epics/base-3.14.12.3/bin/linux-x86/dbExpand  -I. -I.. -I../O.Common -I../../../dbd -I/home/sysuser/epics/soft/modules/seq-2.1.15/dbd -I/home/sysuser/epics/base-3.14.12.3/dbd -o test.dbd ../testInclude.dbd
> Can't open include file "asyn.dbd"
> Error at or before ""asyn.dbd"" in file "../testInclude.dbd" line 2
> Can't open include file "drvAsynSerialPort.dbd"
> Error at or before ""drvAsynSerialPort.dbd"" in file "../testInclude.dbd" line 4
> Can't open include file "drvAsynIPPort.dbd"
> Error at or before ""drvAsynIPPort.dbd"" in file "../testInclude.dbd" line 5
> dbExpand: Input errors, no output generated
> make[3]: *** [../O.Common/test.dbd] Error 1
> make[3]: Leaving directory `/home/sysuser/epics.3.14.12.1/soft/modules/asyn4-21/testApp/src/O.linux-x86'
> make[2]: *** [install.linux-x86] Error 2
> make[2]: Leaving directory `/home/sysuser/epics.3.14.12.1/soft/modules/asyn4-21/testApp/src'
> make[1]: *** [src.install] Error 2
> make[1]: Leaving directory `/home/sysuser/epics.3.14.12.1/soft/modules/asyn4-21/testApp'
> make: *** [testApp.install] Error 2
> Any suggestions to fix this issue?
> Thanks, Chanaka.
Error associated to building asyn4-21 L. C. De Silva
Prev: Error associated to building asyn4-21 L. C. De Silva
Next: Re: Error associated to building asyn4-21 Eric Norum
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  <2013>  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
