1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  <2013>  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  <2013>  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Subject: Re: Mclennan PM600 motor controller
To: Peter Linardakis <[email protected]>
Date: Fri, 13 Dec 2013 10:00:37 -0600
On 12/12/2013 11:24 PM, Peter Linardakis wrote:
Where/when should I expect the debug messages from the PM304 driver to appear?  I don't seem to see any on top of what we had?
Hello Peter,
After iocInit you should have seen,
"motor_init, return from pasynOctetSyncIO->connect for port %s = %d, pasynUser=%p\n"
if there are no errors up to that point, or,
         "motor_init: *PM304 driver disabled*\n");
         "PM304Setup() is missing from startup script.\n");
if an error where detected.
When you issued the command "var drvPM304Debug 10" did you get an error message?
drvPM304Debug -- no such variable.
If so then, you need to edit the motor/motorApp/MclennanSrc/devMclennanMotor.dbd file
by uncommenting this line,
#variable(drvPM304Debug)
then rebuild that directory and your application. Run it.
Hope this helps,
Ron
Mclennan PM600 motor controller Peter Linardakis
RE: Mclennan PM600 motor controller Mark Rivers
RE: Mclennan PM600 motor controller Peter Linardakis
RE: Mclennan PM600 motor controller nick.rees
Prev: RE: Mclennan PM600 motor controller Peter Linardakis
Next: Re: pilatus detecotr modify FileName problem Matt Newville
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  <2013>  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Next: Re: Mclennan PM600 motor controller Torsten Bögershausen
