1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  <2013>  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  <2013>  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Subject: RE: Build of seq-2.1.15 with VS 2010 fails.
To: "Benjamin Franksen" <[email protected]>, "Tagger, Jueri" <[email protected]>, <[email protected]>
Date: Thu, 19 Dec 2013 11:37:02 -0000
Hi Ben,
I have built seq-2.1.15 recently (VS2010), and experienced a similar problem.
The variable needs to be defined as epicsShareExtern - see attached file.
Cheers,
Peter.
-----Original Message-----
From: [email protected] [mailto:[email protected]] On Behalf Of Benjamin Franksen
Sent: 19 December 2013 11:12
To: Tagger, Jueri; [email protected]
Subject: Re: Build of seq-2.1.15 with VS 2010 fails.
Hi Jueri
I am forwarding this to techtalk as I have no idea how to properly solve this build problem.
On Wednesday, December 18, 2013 14:47:27 Tagger, Jueri wrote:
> I tried to build seq-2.1.15 with base-3.14.12.4 using Visual Studio
> 2010. The sequencer build failed at linking the test app
> pvPutAsync.lib with error:
> pvPutAsync.obj : error LNK2001: unresolved external symbol
> _seq_sync_timeout pvPutAsync.exe : fatal error LNK1120: 1 unresolved
> externals
> To my understanding the seq_sync_timeout should be in seq.lib which
> was successfully built earlier and linked in. However, it the missing
> symbol is not there. Any ideas?
and as a follow up:
> Regarding: pvPutAsync.obj : error LNK2001: unresolved external symbol
> _seq_sync_timeout
> It appeared that linking of seq.lib with Visual Studio 2010 SP 1
> requires additional link option: /EXPORT:seq_sync_timeout (Otherwise
> variable double seq_sync_timeout = 10.0; from file
> seq-2.1.15/src/seq/seq_if.c  does not get exported.)
> I just rebuilt the seq.lib with the /EXPORT option but there is surely
> a proper place where this option can be inserted.
Could someone (Andrew?) give advice on how to properly fix this in the sequencer? Should I add some magic annotation to the variable's declaration?
Cheers
Ben
"Make it so they have to reboot after every typo." ― Scott Adams
Attachment: seq_if.c
Description: seq_if.c
New sequencer release fixes build problem on Windows Benjamin Franksen
Re: Build of seq-2.1.15 with VS 2010 fails. Andrew Johnson
Re: Build of seq-2.1.15 with VS 2010 fails. Benjamin Franksen
Prev: Re: Build of seq-2.1.15 with VS 2010 fails. Benjamin Franksen
Next: RE: Design strategies for CSS BOY screens kathryn.baker
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  <2013>  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Next: New sequencer release fixes build problem on Windows Benjamin Franksen
