1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  <2013>  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  <2013>  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Subject: Re: Build of seq-2.1.15 with VS 2010 fails.
To: <[email protected]>
Date: Thu, 19 Dec 2013 22:30:42 +0100
Am Donnerstag, 19. Dezember 2013, 12:40:52 schrieb Andrew Johnson:
> On 12/19/2013 11:40 AM, Mark Rivers wrote:
> [...] if
> seq-2.1.15 has added the variable to a header file that declaration must
> be marked with epicsShareExtern which on Windows expands to either
> #define epicsShareExtern __declspec(dllexport) extern
> or
> #define epicsShareExtern __declspec(dllimport) extern
> depending on whether the header is being included by a file that will be
> part of the same DLL as seq_if.c or must be imported from that DLL.
> I guess Ben's issue might be that he has no header file declaring this
> variable, so the compiler never gets told whether it's going to be an
> import or an export. The solution should thus be to add a suitably
> decorated declaration of the variable to an appropriate header file.
Hi Andrew
thanks for your input. I intentionally did not declare the variable in a
header file because it is a crude hack I added for the tests and was never
meant for public consumption.
Peter Heesterman reported that adding epicsShareExtern inside the C file
solves the build problem so that is what I did. The code in 2.1.16 slightly
differs from his proposed fix because gcc gave a warning about initializing a
variable that was declared extern, so the code is now:
  epicsShareExtern double seq_sync_timeout;
  double seq_sync_timeout = 10.0;
> I suspect that just marking the definition as epicsShareExtern in the
> seq_if.c file may cause problems later.
I hope not ;-) At least, it seems that currently __declspec(dllimport) is not
really needed. If it turns out later that there are cases where it is needed,
I will add the necessary annotation in the code where the variable is used
(inside the tests).
Let me repeat: if you intend your programs to work with future releases of the
sequencer, you should *not* use this variable. I may remove it without further
notice. A proper fix for the issue of configuring the timeout for the SYNC
variants of pvPut and pvGet will appear in version 2.2 of the sequencer.
Cheers
Ben
Attachment: signature.asc
Description: This is a digitally signed message part.
RE: Build of seq-2.1.15 with VS 2010 fails. Mark Rivers
Re: Build of seq-2.1.15 with VS 2010 fails. Andrew Johnson
Prev: Re: Build of seq-2.1.15 with VS 2010 fails. Andrew Johnson
Next: RE: Design strategies for CSS BOY screens tom.cobb
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  <2013>  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Next: notification server Pearson, Matthew R.
