1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  <2014>  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  <2014>  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Subject: Re: VLANS designing,Geographical vs functional?
To: Zhang Yuliang <[email protected]>, tech-talk <[email protected]>
Date: Wed, 8 Jan 2014 16:25:14 +0000
> We are designing VLANS for CSNS(China Spallation Neutron Source).  I
> want to know which method do you choose in your site, geographical or
> functional?  Any advice? Thanks in advance.
At the S-DALINAC we used functional segregation (cf. [1] p. 107f). The
reason for this was security: We wanted to make sure that the office
network is separate from the accelerator's network. It's also a good
idea to keep the data acquisition network of the experiments separate of
the accelerator network. You also might want to consider moving some
machines like configuration databases, archiver machines etc. into some
sort of a demilitarized zone.
Generally, a good starting point would be to use separation analogue to
the social separation of the groups that are maintaining the machines on
your network. This gives each group a reasonable amount of freedom in
their VLAN while making connections to other machines a reasonable thing
to maintain. Note that over-segregation results in a lot of work for the
administrators of your gateways and also might have some impact on
performance. Under-segregation, on the other hand, leads to problems
caused by administrators which are not aware of the details of all
machines on the network as well as security issues.
HTH,
Martin
[1] http://tuprints.ulb.tu-darmstadt.de/3398/
Martin Konrad
Control System Engineer
Facility for Rare Isotope Beams
Michigan State University
640 South Shaw Lane
East Lansing, MI 48824-1321, USA
Tel. 517-908-7253
Email: [email protected]
Prev: Re: Increasing scan rate to 10 kHz Till Straumann
Next: Re: A call to 'assert(capacity != 0)' by thread‏ Dirk Zimoch
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  <2014>  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Prev: Re: Agilent 33522A Function / Arbitrary Waveform Generator Michael Johnson
Next: Re: VLANS designing,Geographical vs functional? Konrad, Martin
ANJ, 17 Dec 2015 · Home · News · About · Talk · Base · Modules · Extensions ·
