Dear All,
This is regarding the installation of Sequencer on Linux Fedora 19 I am able to "make" sequencer and run the Demo Test and EPICS sequencer example without any failure.
But when i tried with "make -s runtests" i got following error log. Is there any problem with installation or its with the runtest. How to short it out.
Thank you
Regards Ganesh
[GMRT@01HW183138 seq]$ make -s runtests snc_test.t .. Can't locate Test/More.pm in @INC (@INC contains: /usr/local/lib64/perl5 /usr/local/share/perl5 /usr/lib64/perl5/vendor_perl /usr/share/perl5/vendor_perl /usr/lib64/perl5 /usr/share/perl5 .) at snc_test.t line 5. BEGIN failed--compilation aborted at snc_test.t line 5. snc_test.t .. Dubious, test returned 2 (wstat 512, 0x200) No subtests run
Test Summary Report ------------------- snc_test.t (Wstat: 512 Tests: 0 Failed: 0) Non-zero exit status: 2 Parse errors: No plan found in TAP output Files=1, Tests=0, 0 wallclock secs ( 0.02 usr + 0.01 sys = 0.03 CPU) Result: FAIL Failed 1/1 test programs. 0/0 subtests failed. array.t ................ ok assign.t ............... ok change.t ............... ok commaOperator.t ........ ok local.t ................ ok opttVar.t .............. ok pvSync.t ............... Starting iocInit iocRun: All initialization complete pvSync.t ............... ok safeModeNotAssigned.t .. ok safeMonitor.t .......... ok userfunc.t ............. Starting iocInit iocRun: All initialization complete userfunc.t ............. ok userfuncEf.t ........... ok bittypes.t ............. Starting iocInit iocRun: All initialization complete bittypes.t ............. ok evflag.t ............... Starting iocInit iocRun: All initialization complete evflag.t ............... ok monitorEvflag.t ........ Starting iocInit iocRun: All initialization complete monitorEvflag.t ........ ok pvGet.t ................ Starting iocInit iocRun: All initialization complete pvGet.t ................ ok pvGetAsync.t ........... Starting iocInit iocRun: All initialization complete pvGetAsync.t ........... ok pvPutAsync.t ........... Starting iocInit iocRun: All initialization complete pvPutAsync.t ........... ok reassign.t ............. Starting iocInit iocRun: All initialization complete reassign.t ............. ok norace.t ............... Starting iocInit iocRun: All initialization complete norace.t ............... ok bittypesIoc.t .......... Starting iocInit iocRun: All initialization complete bittypesIoc.t .......... 1/?
Thanks and Regards
Ganesh Jangir ------------------------------------------------------------------------------------------------------------------------------------------------
To: [email protected] From: Ganesh Jangir/MUM/TCS Date: 12/26/2013 05:45PM Subject: Sequencer Installation error
Dear All,
I am tiring to sequencer of my Linux Machine I am following the step mention in sequencer User Guide 2.1.16(the latest one) Following variable are defined EPICS_BASE, EPICS_HOST_ARCH, LD_LIB_PATH already in epics.
During the the make command the compilation goes in to infinite loop..
make[3]: Entering directory `/home/GMRT/Desktop/epics/extensions/soft/seq/seq-snapshot-2013-12-19/src/snc/O.linux-x86_64' ../../../bin/linux-x86_64/lemon o=. ../snl.lem 3 parsing conflicts. s -b -o lexer.c ../snl.re make[3]: s: Command not found make[3]: [lexer.c] Error 127 (ignored) make[3]: Leaving directory `/home/GMRT/Desktop/epics/extensions/soft/seq/seq-snapshot-2013-12-19/src/snc/O.linux-x86_64' make[3]: Entering directory `/home/GMRT/Desktop/epics/extensions/soft/seq/seq-snapshot-2013-12-19/src/snc/O.linux-x86_64' s -b -o lexer.c ../snl.re make[3]: s: Command not found make[3]: [lexer.c] Error 127 (ignored) make[3]: Leaving directory `/home/GMRT/Desktop/epics/extensions/soft/seq/seq-snapshot-2013-12-19/src/snc/O.linux-x86_64' make[3]: Entering directory `/home/GMRT/Desktop/epics/extensions/soft/seq/seq-snapshot-2013-12-19/src/snc/O.linux-x86_64' s -b -o lexer.c ../snl.re . . runs endless -------------------------------------------------------------------------------------------------------------------------------------------------- ALSO when i tried to run make -s runtests. It again goes in to [GMRT@01HW183138 seq-snapshot-2013-12-19]$ make -s runtests make[3]: s: Command not found make[3]: s: Command not found make[3]: s: Command not found make[3]: s: Command not found : : runs endless ----------------------------------------------------------------------------------------------------------------------------------------------------
Below is complete log.
Please help.
_________________________________________________________________________- -------------------------------------------------------------------------------------------------------------------------------- make -C ./configure install make[1]: Entering directory `/home/GMRT/Desktop/epics/extensions/soft/seq/seq-snapshot-2013-12-19/configure' perl /home/GMRT/Desktop/epics/base-3.14.12.3/bin/linux-x86_64/makeMakefile.pl O.linux-x86_64 ../.. mkdir O.Common make -C O.linux-x86_64 -f ../Makefile TOP=../.. T_A=linux-x86_64 install make[2]: Entering directory `/home/GMRT/Desktop/epics/extensions/soft/seq/seq-snapshot-2013-12-19/configure/O.linux-x86_64' perl /home/GMRT/Desktop/epics/base-3.14.12.3/bin/linux-x86_64/convertRelease.pl checkRelease make[2]: Leaving directory `/home/GMRT/Desktop/epics/extensions/soft/seq/seq-snapshot-2013-12-19/configure/O.linux-x86_64' make[1]: Leaving directory `/home/GMRT/Desktop/epics/extensions/soft/seq/seq-snapshot-2013-12-19/configure' make -C ./src install make[1]: Entering directory `/home/GMRT/Desktop/epics/extensions/soft/seq/seq-snapshot-2013-12-19/src' make -C ./pv install make[2]: Entering directory `/home/GMRT/Desktop/epics/extensions/soft/seq/seq-snapshot-2013-12-19/src/pv' perl /home/GMRT/Desktop/epics/base-3.14.12.3/bin/linux-x86_64/makeMakefile.pl O.linux-x86_64 ../../.. mkdir O.Common make -C O.linux-x86_64 -f ../Makefile TOP=../../.. T_A=linux-x86_64 install make[3]: Entering directory `/home/GMRT/Desktop/epics/extensions/soft/seq/seq-snapshot-2013-12-19/src/pv/O.linux-x86_64'
/usr/bin/g++ -c -D_POSIX_C_SOURCE=199506L -D_POSIX_THREADS -D_XOPEN_SOURCE=500 -DPVCA -D_X86_64_ -DUNIX -D_BSD_SOURCE -Dlinux -D_REENTRANT -O3 -Wall -m64 -fPIC -MMD -I. -I../O.Common -I. -I.. -I../../../include/os/Linux -I../../../include -I/home/GMRT/Desktop/epics/base-3.14.12.3/include/os/Linux -I/home/GMRT/Desktop/epics/base-3.14.12.3/include ../pvNew.cc
/usr/bin/g++ -c -D_POSIX_C_SOURCE=199506L -D_POSIX_THREADS -D_XOPEN_SOURCE=500 -DPVCA -D_X86_64_ -DUNIX -D_BSD_SOURCE -Dlinux -D_REENTRANT -O3 -Wall -m64 -fPIC -MMD -I. -I../O.Common -I. -I.. -I../../../include/os/Linux -I../../../include -I/home/GMRT/Desktop/epics/base-3.14.12.3/include/os/Linux -I/home/GMRT/Desktop/epics/base-3.14.12.3/include ../pv.cc
/usr/bin/g++ -c -D_POSIX_C_SOURCE=199506L -D_POSIX_THREADS -D_XOPEN_SOURCE=500 -DPVCA -D_X86_64_ -DUNIX -D_BSD_SOURCE -Dlinux -D_REENTRANT -O3 -Wall -m64 -fPIC -MMD -I. -I../O.Common -I. -I.. -I../../../include/os/Linux -I../../../include -I/home/GMRT/Desktop/epics/base-3.14.12.3/include/os/Linux -I/home/GMRT/Desktop/epics/base-3.14.12.3/include ../pvCa.cc /usr/bin/ar -rc libpv.a pvNew.o pv.o pvCa.o /usr/bin/ranlib libpv.a /usr/bin/g++ -o libpv.so -shared -fPIC -Wl,-hlibpv.so -L/home/GMRT/Desktop/epics/base-3.14.12.3/lib/linux-x86_64 -Wl,-rpath,/home/GMRT/Desktop/epics/base-3.14.12.3/lib/linux-x86_64 -m64 pvNew.o pv.o pvCa.o -lca -lCom -lpthread -lreadline -lm -lrt -ldl -lgcc Installing shared library ../../../lib/linux-x86_64/libpv.so Installing library ../../../lib/linux-x86_64/libpv.a make[3]: Leaving directory `/home/GMRT/Desktop/epics/extensions/soft/seq/seq-snapshot-2013-12-19/src/pv/O.linux-x86_64' make[2]: Leaving directory `/home/GMRT/Desktop/epics/extensions/soft/seq/seq-snapshot-2013-12-19/src/pv' make -C ./seq install make[2]: Entering directory `/home/GMRT/Desktop/epics/extensions/soft/seq/seq-snapshot-2013-12-19/src/seq' perl /home/GMRT/Desktop/epics/base-3.14.12.3/bin/linux-x86_64/makeMakefile.pl O.linux-x86_64 ../../.. mkdir O.Common make -C O.linux-x86_64 -f ../Makefile TOP=../../.. T_A=linux-x86_64 install make[3]: Entering directory `/home/GMRT/Desktop/epics/extensions/soft/seq/seq-snapshot-2013-12-19/src/seq/O.linux-x86_64' perl ../seq_release.pl 2.1.16 > ../O.Common/seq_release.h Installing generated generic include file ../../../include/seq_release.h
/usr/bin/gcc -c -D_POSIX_C_SOURCE=199506L -D_POSIX_THREADS -D_XOPEN_SOURCE=500 -D_X86_64_ -DUNIX -D_BSD_SOURCE -Dlinux -D_REENTRANT -O3 -g -Wall -m64 -fPIC -MMD -I. -I../O.Common -I. -I.. -I../../../include/os/Linux -I../../../include -I/home/GMRT/Desktop/epics/base-3.14.12.3/include/os/Linux -I/home/GMRT/Desktop/epics/base-3.14.12.3/include ../seq_main.c
/usr/bin/gcc -c -D_POSIX_C_SOURCE=199506L -D_POSIX_THREADS -D_XOPEN_SOURCE=500 -D_X86_64_ -DUNIX -D_BSD_SOURCE -Dlinux -D_REENTRANT -O3 -g -Wall -m64 -fPIC -MMD -I. -I../O.Common -I. -I.. -I../../../include/os/Linux -I../../../include -I/home/GMRT/Desktop/epics/base-3.14.12.3/include/os/Linux -I/home/GMRT/Desktop/epics/base-3.14.12.3/include ../seq_task.c
/usr/bin/gcc -c -D_POSIX_C_SOURCE=199506L -D_POSIX_THREADS -D_XOPEN_SOURCE=500 -D_X86_64_ -DUNIX -D_BSD_SOURCE -Dlinux -D_REENTRANT -O3 -g -Wall -m64 -fPIC -MMD -I. -I../O.Common -I. -I.. -I../../../include/os/Linux -I../../../include -I/home/GMRT/Desktop/epics/base-3.14.12.3/include/os/Linux -I/home/GMRT/Desktop/epics/base-3.14.12.3/include ../seq_ca.c
/usr/bin/gcc -c -D_POSIX_C_SOURCE=199506L -D_POSIX_THREADS -D_XOPEN_SOURCE=500 -D_X86_64_ -DUNIX -D_BSD_SOURCE -Dlinux -D_REENTRANT -O3 -g -Wall -m64 -fPIC -MMD -I. -I../O.Common -I. -I.. -I../../../include/os/Linux -I../../../include -I/home/GMRT/Desktop/epics/base-3.14.12.3/include/os/Linux -I/home/GMRT/Desktop/epics/base-3.14.12.3/include ../seq_if.c
/usr/bin/gcc -c -D_POSIX_C_SOURCE=199506L -D_POSIX_THREADS -D_XOPEN_SOURCE=500 -D_X86_64_ -DUNIX -D_BSD_SOURCE -Dlinux -D_REENTRANT -O3 -g -Wall -m64 -fPIC -MMD -I. -I../O.Common -I. -I.. -I../../../include/os/Linux -I../../../include -I/home/GMRT/Desktop/epics/base-3.14.12.3/include/os/Linux -I/home/GMRT/Desktop/epics/base-3.14.12.3/include ../seq_mac.c
/usr/bin/gcc -c -D_POSIX_C_SOURCE=199506L -D_POSIX_THREADS -D_XOPEN_SOURCE=500 -D_X86_64_ -DUNIX -D_BSD_SOURCE -Dlinux -D_REENTRANT -O3 -g -Wall -m64 -fPIC -MMD -I. -I../O.Common -I. -I.. -I../../../include/os/Linux -I../../../include -I/home/GMRT/Desktop/epics/base-3.14.12.3/include/os/Linux -I/home/GMRT/Desktop/epics/base-3.14.12.3/include ../seq_prog.c
/usr/bin/gcc -c -D_POSIX_C_SOURCE=199506L -D_POSIX_THREADS -D_XOPEN_SOURCE=500 -D_X86_64_ -DUNIX -D_BSD_SOURCE -Dlinux -D_REENTRANT -O3 -g -Wall -m64 -fPIC -MMD -I. -I../O.Common -I. -I.. -I../../../include/os/Linux -I../../../include -I/home/GMRT/Desktop/epics/base-3.14.12.3/include/os/Linux -I/home/GMRT/Desktop/epics/base-3.14.12.3/include ../seq_qry.c
/usr/bin/gcc -c -D_POSIX_C_SOURCE=199506L -D_POSIX_THREADS -D_XOPEN_SOURCE=500 -D_X86_64_ -DUNIX -D_BSD_SOURCE -Dlinux -D_REENTRANT -O3 -g -Wall -m64 -fPIC -MMD -I. -I../O.Common -I. -I.. -I../../../include/os/Linux -I../../../include -I/home/GMRT/Desktop/epics/base-3.14.12.3/include/os/Linux -I/home/GMRT/Desktop/epics/base-3.14.12.3/include ../seq_cmd.c
/usr/bin/gcc -c -D_POSIX_C_SOURCE=199506L -D_POSIX_THREADS -D_XOPEN_SOURCE=500 -D_X86_64_ -DUNIX -D_BSD_SOURCE -Dlinux -D_REENTRANT -O3 -g -Wall -m64 -fPIC -MMD -I. -I../O.Common -I. -I.. -I../../../include/os/Linux -I../../../include -I/home/GMRT/Desktop/epics/base-3.14.12.3/include/os/Linux -I/home/GMRT/Desktop/epics/base-3.14.12.3/include ../seq_queue.c /usr/bin/ar -rc libseq.a seq_main.o seq_task.o seq_ca.o seq_if.o seq_mac.o seq_prog.o seq_qry.o seq_cmd.o seq_queue.o /usr/bin/ranlib libseq.a /usr/bin/g++ -o libseq.so -shared -fPIC -Wl,-hlibseq.so -L/home/GMRT/Desktop/epics/extensions/soft/seq/seq-snapshot-2013-12-19/lib/linux-x86_64 -L/home/GMRT/Desktop/epics/base-3.14.12.3/lib/linux-x86_64 -Wl,-rpath,/home/GMRT/Desktop/epics/extensions/soft/seq/seq-snapshot-2013-12-19/lib/linux-x86_64 -Wl,-rpath,/home/GMRT/Desktop/epics/base-3.14.12.3/lib/linux-x86_64 -m64 seq_main.o seq_task.o seq_ca.o seq_if.o seq_mac.o seq_prog.o seq_qry.o seq_cmd.o seq_queue.o -lpv -lCom -lpthread -lreadline -lm -lrt -ldl -lgcc Installing shared library ../../../lib/linux-x86_64/libseq.so Installing library ../../../lib/linux-x86_64/libseq.a make[3]: Leaving directory `/home/GMRT/Desktop/epics/extensions/soft/seq/seq-snapshot-2013-12-19/src/seq/O.linux-x86_64' make[2]: Leaving directory `/home/GMRT/Desktop/epics/extensions/soft/seq/seq-snapshot-2013-12-19/src/seq' make -C ./lemon install make[2]: Entering directory `/home/GMRT/Desktop/epics/extensions/soft/seq/seq-snapshot-2013-12-19/src/lemon' perl /home/GMRT/Desktop/epics/base-3.14.12.3/bin/linux-x86_64/makeMakefile.pl O.linux-x86_64 ../../.. mkdir O.Common make -C O.linux-x86_64 -f ../Makefile TOP=../../.. T_A=linux-x86_64 install make[3]: Entering directory `/home/GMRT/Desktop/epics/extensions/soft/seq/seq-snapshot-2013-12-19/src/lemon/O.linux-x86_64'
/usr/bin/gcc -c -D_POSIX_C_SOURCE=199506L -D_POSIX_THREADS -D_XOPEN_SOURCE=500 -D_X86_64_ -DUNIX -D_BSD_SOURCE -Dlinux -D_REENTRANT -O3 -g -Wall -m64 -MMD -I. -I../O.Common -I. -I.. -I../../../include/os/Linux -I../../../include -I/home/GMRT/Desktop/epics/base-3.14.12.3/include/os/Linux -I/home/GMRT/Desktop/epics/base-3.14.12.3/include ../lemon.c /usr/bin/g++ -o lemon -m64 lemon.o Installing created file ../../../bin/linux-x86_64/lemon make[3]: Leaving directory `/home/GMRT/Desktop/epics/extensions/soft/seq/seq-snapshot-2013-12-19/src/lemon/O.linux-x86_64' make[2]: Leaving directory `/home/GMRT/Desktop/epics/extensions/soft/seq/seq-snapshot-2013-12-19/src/lemon' make -C ./dev install make[2]: Entering directory `/home/GMRT/Desktop/epics/extensions/soft/seq/seq-snapshot-2013-12-19/src/dev' perl /home/GMRT/Desktop/epics/base-3.14.12.3/bin/linux-x86_64/makeMakefile.pl O.linux-x86_64 ../../.. mkdir O.Common make -C O.linux-x86_64 -f ../Makefile TOP=../../.. T_A=linux-x86_64 install make[3]: Entering directory `/home/GMRT/Desktop/epics/extensions/soft/seq/seq-snapshot-2013-12-19/src/dev/O.linux-x86_64'
/usr/bin/gcc -c -D_POSIX_C_SOURCE=199506L -D_POSIX_THREADS -D_XOPEN_SOURCE=500 -D_X86_64_ -DUNIX -D_BSD_SOURCE -Dlinux -D_REENTRANT -O3 -g -Wall -m64 -fPIC -MMD -I. -I../O.Common -I. -I.. -I../../../include/os/Linux -I../../../include -I/home/GMRT/Desktop/epics/base-3.14.12.3/include/os/Linux -I/home/GMRT/Desktop/epics/base-3.14.12.3/include -I../../../src/seq ../devSequencer.c /usr/bin/ar -rc libseqDev.a devSequencer.o /usr/bin/ranlib libseqDev.a /usr/bin/g++ -o libseqDev.so -shared -fPIC -Wl,-hlibseqDev.so -L/home/GMRT/Desktop/epics/extensions/soft/seq/seq-snapshot-2013-12-19/lib/linux-x86_64 -L/home/GMRT/Desktop/epics/base-3.14.12.3/lib/linux-x86_64 -Wl,-rpath,/home/GMRT/Desktop/epics/extensions/soft/seq/seq-snapshot-2013-12-19/lib/linux-x86_64 -Wl,-rpath,/home/GMRT/Desktop/epics/base-3.14.12.3/lib/linux-x86_64 -m64 devSequencer.o -lseq -lpv -lrecIoc -lsoftDevIoc -lmiscIoc -lrsrvIoc -ldbtoolsIoc -lasIoc -ldbIoc -lregistryIoc -ldbStaticIoc -lca -lCom -lpthread -lreadline -lm -lrt -ldl -lgcc Installing shared library ../../../lib/linux-x86_64/libseqDev.so Installing library ../../../lib/linux-x86_64/libseqDev.a make[3]: Leaving directory `/home/GMRT/Desktop/epics/extensions/soft/seq/seq-snapshot-2013-12-19/src/dev/O.linux-x86_64' make[2]: Leaving directory `/home/GMRT/Desktop/epics/extensions/soft/seq/seq-snapshot-2013-12-19/src/dev' make -C ./snc install make[2]: Entering directory `/home/GMRT/Desktop/epics/extensions/soft/seq/seq-snapshot-2013-12-19/src/snc' perl /home/GMRT/Desktop/epics/base-3.14.12.3/bin/linux-x86_64/makeMakefile.pl O.linux-x86_64 ../../.. mkdir O.Common make -C O.linux-x86_64 -f ../Makefile TOP=../../.. T_A=linux-x86_64 install make[3]: Entering directory `/home/GMRT/Desktop/epics/extensions/soft/seq/seq-snapshot-2013-12-19/src/snc/O.linux-x86_64' ../../../bin/linux-x86_64/lemon o=. ../snl.lem 3 parsing conflicts. s -b -o lexer.c ../snl.re make[3]: s: Command not found make[3]: [lexer.c] Error 127 (ignored) make[3]: Leaving directory `/home/GMRT/Desktop/epics/extensions/soft/seq/seq-snapshot-2013-12-19/src/snc/O.linux-x86_64' make[3]: Entering directory `/home/GMRT/Desktop/epics/extensions/soft/seq/seq-snapshot-2013-12-19/src/snc/O.linux-x86_64' s -b -o lexer.c ../snl.re make[3]: s: Command not found make[3]: [lexer.c] Error 127 (ignored) make[3]: Leaving directory `/home/GMRT/Desktop/epics/extensions/soft/seq/seq-snapshot-2013-12-19/src/snc/O.linux-x86_64' make[3]: Entering directory `/home/GMRT/Desktop/epics/extensions/soft/seq/seq-snapshot-2013-12-19/src/snc/O.linux-x86_64' s -b -o lexer.c ../snl.re .... . . .. Infinite loop
Thanks and Regards
Ganesh Jangir
Notice: The information contained in this e-mail
message and/or attachments to it may contain
confidential or privileged information. If you are
not the intended recipient, any dissemination, use,
review, distribution, printing or copying of the
information contained in this e-mail message
and/or attachments to it are strictly prohibited. If
you have received this communication in error,
please notify us by reply e-mail or telephone and
immediately and permanently delete the message
and any attachments. Thank you
- Re: Sequencer Installation error Jitendra Kodilkar
Re:Re: Failed to install ISR 류수
<2014>
Re: Sequencer Installation error Benjamin Franksen
<2014>
ANJ, 17 Dec 2015 |
Home
News
About
Base
Modules
Extensions
Distributions
Download
Search
EPICS V4
IRMIS
Talk
Bugs
Documents
Links
Licensing
