1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  <2014>  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  <2014>  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Subject: SNL monitor and pvPutComplete
To: "[email protected] Tech-Talk" <[email protected]>
Date: Tue, 21 Jan 2014 17:42:46 -0500
I'm using SNL to perform a potentially long put_callback, using pvPut with the ASYNC option in one state, followed by the use of pvPutComplete in the following state. Then on completion, I read another PV immediately, which has an SNL monitor on it, something like:
unsigned short start_pv; assign start_pv to "{RC}:Start"; monitor start_pv;
unsigned short login_pv; assign login_pv to "{DAS}:Login";
unsigned short status_pv; assign status_pv to "{DAS}:Stat"; monitor status_pv;
state idle {
	/* When we detect a user start. */
	when (start_pv == 1) {
	   login_pv = 1;
	    pvPut(login_pv, ASYNC);
	} state login
state login {
       when (pvPutComplete(login_pv)) {
          if (status_pv != 1) {
	     /*handle error here*/
	  } else {
	     /*it worked */
       } state thenextstate
I have a race condition between the completion of the put_callback and the status_pv variable updating due to a monitor. I sometimes read the value the status PV had before the callback completes. I've tested the underlying system quite a bit, so I suspected a problem with my SNL. I added in a pvGet(status_pv) just before I test that variable, and it seems to have solved it (which maybe just due to the extra time taken to execute the pvGet).
Am I handling this situation incorrectly, or do we know of a problem with monitors in SNL (SEQ Version 2.0.14)? Is the use of pvGet on a monitored variable a bad idea? From reading tech-talk, it might be frowned upon...
Or, is there a better way of doing this, using event flags?
Cheers,
Matt
RE: SNL monitor and pvPutComplete Emmanuel Mayssat
Prev: DLS EtherCAT scanner and unmatched datagrams [SEC=UNCLASSIFIED] LYNCH, Damien
Next: Re: DLS EtherCAT scanner and unmatched datagrams [SEC=UNCLASSIFIED] Jon Nielsen
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  <2014>  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Prev: RE: DLS EtherCAT scanner and unmatched datagrams [SEC=UNCLASSIFIED] ronaldo.mercado
Next: RE: SNL monitor and pvPutComplete Emmanuel Mayssat
ANJ, 17 Dec 2015 · Home · News · About · Talk · Base · Modules · Extensions ·
