1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  <20142015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  <20142015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025
Subject: RE: DLS EtherCAT scanner and unmatched datagrams [SEC=UNCLASSIFIED]
To: Jon Nielsen <[email protected]>, "[email protected]" <[email protected]>
Date: Wed, 22 Jan 2014 00:52:42 +0000
Hi Jon,
Change is to ethercat-1-5-3/ethercatApp/scannerSrc/scanner.c:
diff scanner.c.original scanner.c
162a163,167
>             // gets reply to LRW frame sent last cycle
>             // from network card buffer
>             ecrt_master_receive(master);
>             ecrt_domain_process(domain);
170,173d174
<             // gets reply to LRW frame sent last cycle
<             // from network card buffer
<             ecrt_master_receive(master);
<             ecrt_domain_process(domain);
Damien
-----Original Message-----
Sent: Wednesday, 22 January 2014 11:31 AM
To: [email protected]
Cc: LYNCH, Damien
Subject: Re: DLS EtherCAT scanner and unmatched datagrams [SEC=UNCLASSIFIED]
Hi Damien,
> Have any DLS EtherCAT module users noticed messages like the following in their log?
> Dec 16 15:31:57 (none) kernel: [17651.934011] EtherCAT WARNING 0: 2000 datagrams UNMATCHED!
> Dec 16 15:31:58 (none) kernel: [17652.934010] EtherCAT WARNING 0: 2000 datagrams UNMATCHED!
> Dec 16 15:31:59 (none) kernel: [17653.934010] EtherCAT WARNING 0: 2000 datagrams UNMATCHED!
Yes I have.  I have a fairly basic system running (Linux, EtherLab, r8169, DLS ethercat) and those messages are continuous as long as the scanner is running.  I had been meaning to look into it, but since the ethercat communications were working fine I figured it was a low priority.  I'd be happy to test out your changes if you'd like independent verification.  The system is currently running but the hardware it's connected to is not being used for anything important for a little while.  Cheers,
Jon
Research School of Astronomy and Astrophysics The Australian National University
Ph: +61 2 6125 8901
RE: DLS EtherCAT scanner and unmatched datagrams [SEC=UNCLASSIFIED] ronaldo.mercado
DLS EtherCAT scanner and unmatched datagrams [SEC=UNCLASSIFIED] LYNCH, Damien
Re: DLS EtherCAT scanner and unmatched datagrams [SEC=UNCLASSIFIED] Jon Nielsen
Prev: Re: DLS EtherCAT scanner and unmatched datagrams [SEC=UNCLASSIFIED] Jon Nielsen
Next: RE: SNL monitor and pvPutComplete Emmanuel Mayssat
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  <20142015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025
Next: RE: DLS EtherCAT scanner and unmatched datagrams [SEC=UNCLASSIFIED] ronaldo.mercado
ANJ, 17 Dec 2015 Valid HTML 4.01! · Home · News · About · Base · Modules · Extensions · Distributions ·
