1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  <2014>  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  <2014>  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Subject: caget.c patch for dynamic array sizing
To: Techtalk <[email protected]>, Andrew Johnson <[email protected]>
Date: Fri, 24 Jan 2014 16:32:34 -0800
Hi Andrew,
We've been trying to reduce network bandwidth on
CA image transfers by using ROI to reduce the required
data, and just noticed that the default for the caget
command line tool always fetches the full array, even
if NORD is less than NELM.
This happens because caget currently defaults to synchronous
get, and only the -c async option supports dynamic array sizing.
As async vs sync CA is a subtle distinction that doesn't matter for
most of our users, I've added an option to our caget to request
synchronous get and changed the default to async.
I think this could be useful for the broader community,
so here's a patch that does this.
- Bruce
Bruce Hill
Member Technical Staff
SLAC National Accelerator Lab
2575 Sand Hill Road M/S 10
Menlo Park, CA  94025
Index: src/catools/caget.c
--- src/catools/caget.c	(revision 15563)
+++ src/catools/caget.c	(revision 15565)
@@ -57,7 +57,8 @@
     "  -h: Help: Print this message\n"
     "Channel Access options:\n"
     "  -w <sec>: Wait time, specifies CA timeout, default is %f second(s)\n"
-    "  -c: Asynchronous get (use ca_get_callback and wait for completion)\n"
+    "  -c: Asynchronous get (default, uses ca_array_get_callback and waits for completion)\n"
+    "  -G: Synchronous  get (use ca_array_get, no dynamic array sizing)\n"
     "  -p <prio>: CA priority (0-%u, default 0=lowest)\n"
     "Format options:\n"
     "      Default output format is \"name value\"\n"
@@ -376,7 +377,7 @@
     int n;
     int result;                 /* CA result */
     OutputT format = plain;     /* User specified format */
-    RequestT request = get;     /* User specified request type */
+    RequestT request = callback;/* User specified request type */
     IntFormatT outType;         /* Output type */
     int count = 0;              /* 0 = not specified by -# option */
@@ -389,7 +390,7 @@
     LINE_BUFFER(stdout);        /* Configure stdout buffering */
-    while ((opt = getopt(argc, argv, ":taicnhsSe:f:g:l:#:d:0:w:p:F:")) != -1) {
+    while ((opt = getopt(argc, argv, ":taiGcnhsSe:f:g:l:#:d:0:w:p:F:")) != -1) {
         switch (opt) {
         case 'h':               /* Print usage */
             usage();
@@ -400,6 +401,9 @@
         case 'a':               /* Wide output mode */
             complainIfNotPlainAndSet(&format, all);
             break;
+        case 'G':               /* Synchronous mode */
+            request = get;
+            break;
         case 'c':               /* Callback mode */
             request = callback;
             break;
Re: caget.c patch for dynamic array sizing Andrew Johnson
Prev: Re: Help with MEDM. Diego Henrique Dorta
Next: App build Error : menu not found Sud Roy
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  <2014>  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Next: Re: caget.c patch for dynamic array sizing Andrew Johnson
ANJ, 17 Dec 2015 · Home · News · About · Talk · Base · Modules · Extensions ·
