1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  <20142015  2016  2017  2018  2019  2020  2021  2022  2023  2024  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  <20142015  2016  2017  2018  2019  2020  2021  2022  2023  2024
Subject: Re: Build problem of EPICS R3.14.12 (.../ExtUtils/xsubpp not found)
To: EPICS Tech-Talk <[email protected]>
Date: Sun, 26 Jan 2014 20:53:45 +0100
On 29.08.2013 19:42, Konrad, Martin wrote:
Hi Jim,
Can't open perl script "/usr/lib/perl/5.14.2/ExtUtils/xsubpp": No
such file or directory
I've no idea what Linux distro you're using but it looks like a problem
caused by a missing package. For Debian this file should be in a package
named perl-modules or libextutils-parsexs-perl. Please make sure you
have the right package installed.
Just for the records (so it can be found using tech-talk's search engine):
On RedHat based systems (RHEL, CentOS, SL, etc.) installing the package perl-ExtUtils-CBuilder will do.
~Ralph
Prev: RE: App build Error : menu not found Mooney, Tim M.
Next: EPICS driver for CAEN NIM8304 or N1471 Xihui Chen
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  <20142015  2016  2017  2018  2019  2020  2021  2022  2023  2024
Prev: SOLVED - App build Error : menu not found Sud Roy
ANJ, 17 Dec 2015 Valid HTML 4.01! · Home · News · About · Base · Modules · Extensions · Distributions · Download ·
