1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  <2014>  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  <2014>  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Subject: EDM XY Graph Trace N Field
To: [email protected]
Date: Wed, 29 Jan 2014 09:11:41 +0000
I'm using EDM version 1-12-89. I'm plotting a Waveform using the X-Y graph widget with the following trace properties:
X - Left blank for a chronological plot
Y - My waveform PV $(P)WAVEFORM
N - The NORD field of my waveform $(P)WAVEFORM.NORD
The waveform record has NELM = 1000 but it is not always full. My understanding from reading the help is that the X-Y graph should look at the N field and use the value to set the number of points to plot. However, whenever I open the screen I get messages like
Cannot find tag: nPv, near line 299
and the plot always plots 1000 points, even if the value of NORD is 500 (or anything less than 1000).
Has anyone else successfully used the N field of the X-Y graph widget?
Thanks, Alan
Prev: Re: iocLog Ralph Lange
Next: Re: Binding an IOC to a single network interface Ralph Lange
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  <2014>  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Next: Command to print out dynamically assigned TCP port Shankar, Murali
ANJ, 17 Dec 2015 · Home · News · About · Talk · Base · Modules · Extensions ·
