1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  <2014>  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  <2014>  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Subject: Re: epicsTime::strftime
To: "Pearson, Matthew R." <[email protected]>
Cc: "[email protected] list" <[email protected]>
Date: Wed, 29 Jan 2014 13:00:43 -0600
Hi Matt,
On 01/28/2014 02:15 PM, Pearson, Matthew R. wrote:
> I may have come across a problem with strftime in epicsTime.cpp. I'm
> finding that it's rounding the fractional seconds part, but not the
> seconds if the fractional seconds goes to zero. For example:
> if epicsTime::show() produces:
> epicsTime: Tue Jan 28 2014 11:22:53.999977939
> the corresponding epicsTime::strftime() produces:
> 2014-01-28 11:22:53.000
> if the format is: "%Y-%m-%d %H:%M:%S.%03f"
> Has anyone come across this before?
We don't have any tests that involve rounding into the integer seconds
field, and actually there is a fundamental problem with doing that: What
output should the format string "%S %06f %03f" generate (which is
currently legal, if unusual)? The %06f directive should /not/ round the
%S value up to 54, but with the %03f directive the %S /should/ round up.
There is also the complexity of how the two separate directives %S and
%f would communicate; the current code makes a single pass through the
format string, but for the fractional part to affect the seconds part
we'd have to change that somehow, and as the above example suggests
there are pitfalls in doing that.
Eric Norum suggests that epicsTime::strftime() should never round the
fractions up if they're going to roll over into integer seconds. That
should be relatively easy to implement and only gives a small error in
the worst case. If someone wants to work on that I'd be happy to see a
patch (epicsTime::strftime  is in src/libCom/osi/epicsTime.cpp).
- Andrew
Advertising may be described as the science of arresting the human
intelligence long enough to get money from it. -- Stephen Leacock
Re: epicsTime::strftime Andrew Johnson
epicsTime::strftime Pearson, Matthew R.
Prev: RE: EPICS driver for CAEN NIM8304 or N1471 tom.cobb
Next: Command to print out dynamically assigned TCP port Shankar, Murali
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  <2014>  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Prev: epicsTime::strftime Pearson, Matthew R.
Next: Re: epicsTime::strftime Andrew Johnson
ANJ, 17 Dec 2015 · Home · News · About · Talk · Base · Modules · Extensions ·
