which seems to imply that the only valid contents are 0 or 1.
I see that TPRO is defined as a UCHAR, in the section earlier, so I am wondering…..
I need to print varied amounts of information on a record as it’s being processed, during a debugging session, so can I plan on using values assigned in TPRO -other- than just 0 and 1 (2,3….) to vary the amount of information printed by the device driver.
Unless this is a problem, can the definition of that field be adjusted to state that numbers greater than 0 print information on the record each time it is processed?
Later-
David Dudley
