Shudder again.
I recommend a look at the c99 standard (6.7.2.1; paragraph 10)
An implementation may allocate any addressable storage unit large
enough to hold a bit-
field. If enough space remains, a bit-field that immediately follows
another bit-field in a
structure shall be packed into adjacent bits of the same unit. If
insufficient space remains,
whether a bit-field that does not fit is put into the next unit or
overlaps adjacent units is
implementation-defined. The order of allocation of bit-fields within a
unit (high-order to
low-order or low-order to high-order) is implementation-defined. The
alignment of the
addressable storage unit is unspecified.
Hence any assumption about what storage unit the compiler uses, how
adjacent bits
are packed across a storage-unit boundary and in what order bits are
allocated
(LSB->MSB or MSB->LSB) is *not*portable*. This may change from compiler
to compiler
- even from one version to another.
IMHO it is not a good idea to use bitfields the way the motor code does
(i.e.,
making assumptions about their layout). You can find a lot of
discussions on the
subject in the forums.
- Till
PS:
Just for illustration of the point:
struct A {
unsigned long a1: 24;
unsigned long a2: 24;
unsigned short a3: 16;
is stored (by gcc-4.7.3) into 3 32-bit words (i386) or one 64-bit word
(x86_64),
respectively.
Another one: the same gcc packs bitfields together differently
(admittedly in
a way we'd expect it to do it) depending on whether we use chars or shorts:
union BF4 {
struct {
unsigned char a: 4;
unsigned char b: 8;
} charfield;
struct {
unsigned short a: 4;
unsigned short b: 8;
} shortfield;
int
main()
union BF4 bf;
printf("Sizeof union: %i\n", sizeof(bf));
printf("Sizeof charfield: %i\n", sizeof(bf.charfield));
printf("Sizeof shortfield: %i\n", sizeof(bf.shortfield));
memset(&bf, 0, sizeof(bf));
/* set 'a' via charfield */
bf.charfield.a = 0xf;
/* read-back as shortfield */
printf("0x%1x -- expected 0xf\n", bf.shortfield.a);
/* set 'b' via charfield */
bf.charfield.b = 0xff;
printf("0x%1x -- expected 0xff\n", bf.shortfield.b);
}.4)
However: the point is that there is no *guarantee* for a particular layout.
Search the gcc documentation for '-Wpacked-bitfield-compat' for a case
where the layout changed between gcc versions (around 4.4).
On 02/07/2014 07:56 AM, Ron Sluiter wrote:
On 2/7/2014 9:21 AM, [email protected] wrote:
I suggest to remove the switch and replace the occurrence of MSB_First with the EPICS provided endianness switch:
+#include <epicsEndian.h>
-#ifdef MSB_First
+#if (EPICS_BYTE_ORDER == EPICS_ENDIAN_BIG)
Thanks for the suggestion but MSB_First/LSB_First is set to indicate how
C/C++ bit fields are packed, not endianness.
What compiler and compiler version are you using?
Ron
- motorRecord on linux-arm Jens . Eden
- Re: motorRecord on linux-arm Ron Sluiter
Re: asyn driver problem running Linux 3.8.13 with arm processor Andrew Johnson
Re: asyn driver problem running Linux 3.8.13 with arm processor Till Straumann
<2014>
2025
Re: motorRecord on linux-arm Till Straumann
<2014>
2025
