1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  <2014>  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  <2014>  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Subject: Re: Binding an IOC to a single network interface
To: Andrew Johnson <[email protected]>, "[email protected]" <[email protected]>
Date: Tue, 11 Feb 2014 18:52:09 +0100
Andrew.
I actually don't think it's the concurrency problems that are hard to tackle.
Freddie's patch modifies the cast_server() and req_server().
The former is already designed to run as a separate task. cast_server() could
easily be parametrized cast_server(bind_addr) and a separate task be spawned
for each address.
Multiple sockets bound to different addresses can be handled by req_server()
via good-ole 'select'.
There are other problems, though - which AFAIK haven't been mentioned yet:
The identity of the TCP server is stored in global variables 'ca_server_addr', 'ca_server_port'
which are used when answering search replies:
  ca_server_addr is set from the EPICS_CAS_ADDR env-var (0 if unset)
ca_server_port is set from EPICS_CAS_SERVER_PORT or EPICS_CA_SERVER_PORT or CA_SERVER_PORT. If binding of the TCP socket to ca_server_port fails (EADDRINUSE) then this socket is bound to an
arbitrary port (0) and ca_server_port read back from the system.
The problem now is that if there are multiple TCP sockets bound to different ports then there is no easy way to know which one to use. 'ca_server_port' would have to be expanded into a list (one for each configured socket address) and corresponding lookup logic would have to be implemented and built into the handling of search replies.
It is not clear what the semantics of EPICS_CAS_ADDR should be once multiple
addresses are set in EPICS_CAS_INTF_ADDR_LIST.
Finally, there is another issue to resolve if we want to be compatible with CAS:
When you list an interface address in EPICS_CAS_INTF_ADDR_LIST and bind the UDP socket to this address then this socket will not receive broadcasts (you could list the IF's broadcast
address instead but then the socket wouldn't receive unicasts).
CAS handles this by automatically creating a second socket bound to
the IF's broadcast address. This is used to receive UDP messages. However, a comment mentions an additional problem: apparently under solaris (no idea if this is still true) when you send from the socket bound to the broadcast address then the broadcast address will be used as the sender's address (rather than the IF address through which the datagram leaves). In order to work around this problem, CAS uses two sockets (for each IF): one bound to the broadcast address (for reception) and another one bound to the unicast
address (for reception on the unicast address and for sending replies).
So yeah, I agree, handling this in the most general way is not trivial.
Given that, I would argue that the approach taken by the existing patch
gives a considerable gain for a small effort whereas the effort required
for the 'clean' solution is considerable yielding only a small additional gain (I don't think that there are that many use cases where you would really need
a interface list with multiple entries) and thus restricting the list to
one entry is reasonable.
The remaining cases (restricting CA to a subset of IFs with multiple members)
can always be addressed with administrative means (e.g., firewall rules).
- Till
PS:
Another approach (albeit deviating from what CAS does) would be just limiting the address(es) the UDP server binds to. The TCP server would still use the wildcard
address. However, CA searches would only be satisfied when targeting one
of the addresses where the UDP server listens. This would be a little easier to implement but still face some of the problems mentioned above (listen on uni-
+ bcst- sockets, solaris hack...)
On 02/10/2014 11:46 PM, Andrew Johnson wrote:
On 1/22/14, 8:30 AM, [email protected] wrote:
we are looking to run a set of IOCs that bind channel access to just
the loopback interface on the computer; however I saw from the 3.14
docs that EPICS_CAS_INTF_ADDR_LIST is not currently implemented in the
iocCore CA Server. I had a look at the code in base/src/rsrv and the
attached diff (against 3.14.12.2) seems to work for us with:
EPICS_CAS_INTF_ADDR_LIST=127.0.0.1
EPICS_CAS_BEACON_ADDR_LIST=127.255.255.255
I was just wondering if these additions are sufficient, or have I
missed something elsewhere that either needs changing too or might
cause issues later on?
I agree with Ralph's assessment, this patch looks like it should do what
is necessary to bind the server to one interface/IP address.
On 28.01.2014 23:28, J. Lewis Muir asked:
Have you had a chance to consider the patch sent by Freddie?  You seem
open to reviewing and accepting such a patch in the following Tech-Talk
post:
    http://www.aps.anl.gov/epics/tech-talk/2013/msg01493.php
I haven't looked at the patch, but the ability to specify the addresses
on which the IOC CA server listens has been a feature I've wished for
for a long time.
I am indeed happy to review and accept patches that will implement this
functionality. The main limitation of Freddie's patch is that it only
accepts a single hostname or IP address in the EPICS_CAS_INTF_ADDR_LIST
variable (as comments in his code acknowledge). It won't help you if you
need to configure an IOC to bind to more than one interface. I would be
reluctant to incorporate these changes into Base without the full
multi-interface functionality, which also seems to be Ralph's preference:
On 01/29/2014 03:15 AM, Ralph Lange added:
At first glance, this patch looks fine and should cover almost all use
cases. That feature has been on the wish list for a long time, I know.
However, I would prefer a slightly more elaborate implementation that
makes the server side environment variables work the same on both CAS
and rsrv. (This will also minimize the necessary changes in the
documentation.)
The work needed to support multiple independently-configured interfaces
is unfortunately not trivial, the current code in src/rsrv uses the
INADDR_ANY wild-card to open a socket on all the currently configured
interfaces at once. As a result it only needs one thread to handle the
UDP socket and one thread for the TCP socket.
To allow configuring of multiple interfaces implies creating multiple
UDP and TCP sockets, so we have to add a list to hold the parsed
interface addresses and split the existing code up to create a separate
task for each socket. Adding those new tasks implies checking for
sufficient mutexes and possible deadlocks, and adding information about
them to the CA server-report 'casr' output.
This isn't impossible to do, but as I said it's not trivial; I could see
it taking a few weeks for someone to get it right.
However this doesn't take away from the usefulness of Freddie's patch;
it if meets the needs of some sites they can still apply it locally.
- Andrew
Re: Binding an IOC to a single network interface Andrew Johnson
Binding an IOC to a single network interface freddie.akeroyd
Re: Binding an IOC to a single network interface J. Lewis Muir
Re: Binding an IOC to a single network interface Ralph Lange
Prev: RE: Area Detector IOC: how to change MAXSIZE X and Y? Ivashkevych, Oksana
Next: Re: Binding an IOC to a single network interface Andrew Johnson
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  <2014>  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Prev: Re: Binding an IOC to a single network interface Andrew Johnson
ANJ, 17 Dec 2015 · Home · News · About · Talk · Base · Modules · Extensions ·
